Canbt fix libelfso0 proble
Old   January 9, 2007, 11:42
Default Hello I can't really go throug
clo
clo
clo is on a distinguished road
Hello I can't really go through FoamX to work: here there is the error:
nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory
I know it is a known error but after trying to fix it with other posts solutions I quit beacuse nothing worked
I'm using suse 10 with OFoam 1.3; P4 1G ram
Anybody has fixed it on Suse?
thany ciao
clo is offline   Reply With Quote
Old   January 9, 2007, 12:43
Default Hi clo, although I am debia
Holger Blasum
holgerblasum is on a distinguished road
Hi clo,
although I am debian myself I'd guess
http://www.rpmfind.net//linux/RPM/op...5-45.i586.html
does the job for you.
Download ftp://fr2.rpmfind.net/linux/opensuse/distribution/SL-10.1/inst-source/suse/i586/ libelf-0.8.5-45.i586.rpm
then run (as root) rpm -i libelf-0.8.5-45.i586.rpm
I have checked that it contains a /usr/lib/libelf.so.0. In case you already have that file and the problem persists, run "ldconfig" (as root). If the problem still persists, please post the error message and the output of "ls -la /usr/lib/libelf.so.*".
HTH, Holger
holgerblasum is offline   Reply With Quote
Old   January 9, 2007, 13:05
Default Hi Holger, thank you for the h
clo
clo
Hi Holger, thank you for the hints! unfortunatly I can't try now but I will as soon as I can!I will post the results!
thanx ciao
Old   January 10, 2007, 04:17
Default Hi Holger, actually a simple i
clo
clo
Hi Holger, actually a simple installation of lielf via yast solved the problem...mhm...i feel stupid but I remember that I looked inside /usr/lib and libelf.so.0 was there! That's way I tried to do links and other stuff to make it work! I any case the problem is solved and what can I say...thanx!
ciao
Boundary condition setting for water hammer proble yizhou FLUENT 1 October 12, 2007 12:16
FoamX libelfso0 nunoinlux OpenFOAM Bugs 6 September 11, 2007 20:13
Ubuntu and finding libelfso0 shaun OpenFOAM Installation 3 April 30, 2007 18:40
FoamX libelfso0 mockealm OpenFOAM Installation 6 June 29, 2006 15:37
Can I use LES to simulate steady combustion proble Ai Yuanfang FLUENT 2 September 20, 2004 20:54
