March 8, 2005, 08:47 |
has already someone
has already someone tried to compile OpenFoam with Intels C++ compiler? If yes, are there known problems? What do I need to change/adapt? -marcus |
March 8, 2005, 10:22 |
Yes the Intel C++ compiler is
Rep Power: 22 |
Yes the Intel C++ compiler is supported and OpenFOAM should compile with it. However we did not get much if any speed improvement even for the Itanium 2 chip and so encourage people to use the latest gcc compiler instead.
November 28, 2006, 12:31 |
I tried to compile OpenFO
Rolando Maier
I tried to compile OpenFOAM on an Intel Itanium machine with the icc 9.1. I set -gcc-version=410 to be compatible with the gcc version 4.1 I used before. Compiling "triSurface.C" following error occured: SOURCE=triSurface/triSurface.C ; foamMpiCC -gcc-version=410 -DlinuxIA64 -DDP -wd654,819,1125,1476,1505,1572 -O3 -ftz -DNoRepository -I/home/cluster/t7861aa/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -KPIC -c $SOURCE -o Make/linuxIA64I64DPOpt/triSurface.o triSurface/triSurface.C(733): error: type "Foam::List<t>::List [with T=Foam::labelledTri]" is not a class template PrimitivePatch<labelledtri,> ^ triSurface/triSurface.C(733): error: "PrimitivePatch" is not a nonstatic data member or base class of class "Foam::triSurface" PrimitivePatch<labelledtri,> ^ triSurface/triSurface.C(735): error: expected a ")" List<labelledtri>(0), ^ triSurface/triSurface.C(741): error: no default constructor exists for class "Foam::PrimitivePatch<foam::labelledtri,>" {} ^ Can anyone help me? Thanks in advance Rolando |
November 28, 2006, 13:26 |
Well, mine compiles and runs f
Hrvoje Jasak
Rep Power: 33 |
Well, mine compiles and runs fine - this is what I've got around line 733:
// Construct null triSurface::triSurface() : triSurfacePatch ( List<labelledtri>(0), pointField(0) ), patches_(0), sortedEdgeFacesPtr_(NULL), edgeOwnerPtr_(NULL) {} What does your code say? Hrv
November 28, 2006, 14:07 |
Hi Hrvoje,
it needs a few hou
Rolando Maier
Hi Hrvoje,
it needs a few hours until I can access the Itanium machine again. IŽll tell you, if it will work. By the way. Do I have to define triSurfacePatch or is it a member of OpenFOAM? Rolando |
November 28, 2006, 14:13 |
Oh, I remmeberfixing a whole l
Hrvoje Jasak
Rep Power: 33 |
Oh, I remmeberfixing a whole lot of those. In:
/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/triSurface/triSurface/triSurfacePatch.H there should be a typedef: namespace Foam { typedef PrimitivePatch AB labelledTri, List, pointField AB triSurfacePatch; } (the stupid forum software does not like angled brackets so I've replaced them by AB - I'm sure you can follow). From there onwards, you need to replace all explicit statements like: PrimitivePatch AB labelledTri, List, pointField AB with triSurfacePatch. The compiler gets confused, but in any case it looks nicer like this. Hrv
November 28, 2006, 14:16 |
Thaks Hrvoje,
IŽll try it and
Rolando Maier
Thaks Hrvoje,
IŽll try it and tell you what happens. Rolando |
November 29, 2006, 06:19 |
I tried using triSurfaceP
Rolando Maier
I tried using triSurfacePatch and everything works fine. Thanks for that Hrvoje. IŽve one more fundamental question: I set the path to the gcc 4.1.0 libraries into LD_LIBRARY_PATH. (Because the Intel compiler should perform compatible to gcc 4.1.0) Otherwise I get an error like this: SOURCE_DIR=OSspecific/Unix/signals SOURCE=OSspecific/Unix/signals/sigFpe.C ; icpc -gcc-version=410 -DlinuxIA64 -DDP -wd654,819,1125,1476,1505,1572 -O3 -ftz -DNoRepository -DWM_PROJECT_VERSION='"'1.3'"' -I/home/cluster/t7861aa/OpenFOAM/OpenFOAM-1.3/src/zlib-1.2.1 -I/home/cluster/t7861aa/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -KPIC -c $SOURCE -o Make/linuxIA64I64DPOpt/sigFpe.o /usr/include/g++/sstream(181): error: identifier "_M_buf_size" is undefined _M_buf_size = _M_string.size(); ^ detected during: instantiation of "std::basic_stringbuf<_chart,>::basic_stringbuf(co nst std::basic_stringbuf<_chart,>::__string_type &, std::ios_base::openmode={std::_Ios_Openmode}) [with _CharT=char, _Traits=std::char_traits<char>, _Alloc=std::allocator<char>]" at line 355 instantiation of "std::basic_istringstream<_chart,>::basic_istrings tream(const std::basic_istringstream<_chart,>::__string_type &, std::ios_base::openmode={std::_Ios_Openmode}) [with _CharT=char, _Traits=std::char_traits<char>, _Alloc=std::allocator<char>]" /usr/include/g++/sstream(187): error: identifier "_M_buf_size_opt" is undefined _M_buf_size_opt = 512; ^ detected during: instantiation of "std::basic_stringbuf<_chart,>::basic_stringbuf(co nst std::basic_stringbuf<_chart,>::__string_type &, std::ios_base::openmode={std::_Ios_Openmode}) [with _CharT=char, _Traits=std::char_traits<char>, _Alloc=std::allocator<char>]" at line 355 instantiation of "std::basic_istringstream<_chart,>::basic_istrings tream(const std::basic_istringstream<_chart,>::__string_type &, std::ios_base::openmode={std::_Ios_Openmode}) [with _CharT=char, _Traits=std::char_traits<char>, _Alloc=std::allocator<char>]" . . . Is it legal what IŽm doing, to set the gcc lib-path in addition to the intel compiler path in order to avoid these errors? Thanks in advance. Rolando |
November 29, 2006, 06:38 |
Try using -cxxlib-icc as a com
Hrvoje Jasak
Rep Power: 33 |
Try using -cxxlib-icc as a compiler option.
Hrv
November 29, 2006, 07:07 |
Thanks a lot Hrvoje,
it seems
Rolando Maier
it seems to work. Rolando |
Intel compiling problem | cosimobianchini | OpenFOAM Installation | 1 | March 6, 2008 16:59 |
Compiling with Intel compiler icc90 | hjasak | OpenFOAM Installation | 19 | October 27, 2007 11:35 |
CPU:Intel 3.0E or 3.0C | Andrew | CFX | 2 | May 24, 2004 13:00 |
AMD MP vs INTEL Xeon | Albert | Siemens | 6 | February 19, 2003 09:50 |
INTEL vs. AMD | Michael Bo Hansen | CFX | 9 | June 19, 2001 16:54 |
