FoamX problem
Old   May 5, 2006, 09:06
Default Hi Guys, I just installed o
joegi
joegi is on a distinguished road
Hi Guys,
I just installed openfoam, but I'm having the following problem when I try to run FoamX, here is the message:
Starting NameServer with inet:flubio04.diam.unige.it:1234 ...
nsd: error while loading shared libraries: libelf.so.O: cannot open shared object file: no such file or directory.
I'm running under linux fedora 5
Hope you can help me,
Cheers
joegi is offline   Reply With Quote
Old   May 5, 2006, 09:28
Default It's been discussed here: htt
Francesco Del Citto
fra76 is on a distinguished road
http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/2085
I hope this can help you!
I'm running OpenFOAM under FC5, both 32 and 64 bit, and it works fine.
fra76 is offline   Reply With Quote
Old   June 17, 2006, 09:43
Default I have tried doing the linking
Vedran C
vcoralic is on a distinguished road
I have tried doing the linking method proposed in that thread
# cd /usr/lib
# ln -s libelf.so.1 libelf.so.0
but i get the following error:
Starting NameServer with inet:localhost.localdomain:1234 ...
Starting FoamX Host Browser with inet:localhost.localdomain:1234 ...
FoamXHostBrowser: error while loading shared libraries: /home/Vedran/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libFoamX.so: cannot restore segment prot after reloc: Permission denied
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 29989).
Can you help me?
vcoralic is offline   Reply With Quote
Old   June 17, 2006, 11:11
Default Hi; It works well with me o
mer
merrouche djemai
mer is on a distinguished road
Hi;
It works well with me on fedora 5.0 :
as root
# cd /usr/lib
Then restart the computer.
mer is offline   Reply With Quote
Old   June 17, 2006, 11:38
Default In similar cases on Suse I had
Hrvoje Jasak
In similar cases on Suse I hadto install tha package that provides libelf. If the problem persists, try rebuilding FoamX:
util
cd preProcessing/FoamX
rmoall
./Allwmake
Hrv
Hrvoje Jasak
Old   June 17, 2006, 13:03
Default Well I can't seem to be able t
Vedran C
Well I can't seem to be able to fix this problem.
The error does change though once I enable my ethernet connection..
Before ethernet connection, I get the above mentioned error. But once I connect I get this error:
[Vedran@dhcppc5 ~]$ FoamX
Starting NameServer with inet:dhcppc5:1234 ...
uncaught MICO exception: IDL:omg.org/CORBA/INITIALIZE:1.0 (0, not-completed)
/home/Vedran/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 127: 6802 Aborted nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
also, the foamInstallationTest starts giving me an error after the connection
Checking networking...
Action Result Crit
Pinging_dhcppc5 No_entry_for_"dhcppc5"_in_/etc/hosts yes
WARNING: CRITICAL ERROR
Pinging_localHost Successful yes
Test_rsh: Not_active* yes
Test_ssh: Not_active* yes
FATAL ERROR: No remote shell available.
Foam1.3 enviroment requires either ssh and/or rsh.
Contact your system administrator.
Somehow I am starting to think this maybe somewhat of a networking error. Does anyoen have an idea?
Old   June 19, 2006, 02:47
Default http://www.cfd-online.com/cgi-
Mattijs Janssens
mattijs is on a distinguished road
http://www.cfd-online.com/cgi-bin/Op...=7681#POST7681
mattijs is offline   Reply With Quote
Old   June 21, 2006, 02:57
Default Well umm, I tried everything t
Vedran C
Well umm, I tried everything that you guys suggested and I was unable to solve the problem. However, today, I don't know what happened, but the problem just disappeared. Anyways, whatever happened, I am grateful =).
Thanks everybody!
Old   November 5, 2006, 06:06
Default I have the same error, but i h
heliang
billpeace is on a distinguished road
I have the same error, but i have solve it.
The reason for this problem maybe is you don't open port. When i close firewall, it works well.
billpeace is offline   Reply With Quote
Problem with starting FoamX laker OpenFOAM Installation 2 May 13, 2008 09:34
Problem about FoamX williamscn OpenFOAM Installation 8 September 17, 2007 23:18
FoamX problem richardhsieh OpenFOAM Installation 4 September 17, 2007 22:41
Problem running FoamX ianz8802 OpenFOAM Installation 11 March 23, 2007 11:22
FoamX nsref problem svun OpenFOAM Installation 1 June 2, 2006 04:49
