October 30, 2006, 04:41 |
when i run the command as the
heliang
Rep Power: 17 |
when i run the command as the following
if [ "$WM_MPLIB" = "LAM" -a ! -r $LAM_ARCH_PATH/lib/libmpi.a -a ! -r $LAM_ARCH_PATH/lib/libmpi.so ] then cd $LAMHOME gmake distclean rm -rf $LAM_ARCH_PATH ./configure \ --prefix=$LAM_ARCH_PATH \ --enable-shared \ --disable-static \ --without-romio \ --without-mpi2cpp \ --without-profiling \ --without-fc there are a error: ================================================== ========================== == Configuring LAM version 7.1.1 ================================================== ========================== *** Initialization, setup checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes configure: builddir: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1 configure: srcdir: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1 checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu installing to directory "/export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPO pt" *** C compiler and preprocessor checking if want debugging output support... no checking for gcc... gcc checking for C compiler default output file name... configure: error: C compiler cannot create executables the futher information in the config.log $ ./configure --prefix=/export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linu xGcc4DPOpt --enable-shared --disable-static --without-romio --without-mpi2cpp --without-profiling --without-fc ## --------- ## ## Platform. ## ## --------- ## hostname = console uname -m = i686 uname -r = 2.4.20-8smp uname -s = Linux uname -v = #1 SMP Thu Mar 13 17:45:54 EST 2003 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = i686 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOp t/bin PATH: /export/home/heliang/OpenFOAM/linux/j2sdk1.4.2_05/bin PATH: /export/home/heliang/OpenFOAM/linux/gcc-4.1.0/bin PATH: /export/home/heliang/OpenFOAM/heliang-1.3/applications/bin/linuxGcc4DPOpt PATH: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt PATH: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/wmake PATH: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/bin PATH: /usr/kerberos/bin PATH: /usr/local/bin PATH: /usr/bin PATH: /bin PATH: /usr/X11R6/bin PATH: /usr/java/j2sdk1.4.1_02/bin PATH: /usr/java/j2sdk1.4.1_02/jre/bin PATH: /usr/local/jakarta-tomcat-4.1.18/bin PATH: /export/ljrs/bin PATH: /export/ljrs/sbin PATH: /export/home/heliang/OpenFOAM/linux/paraview-2.4.2/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1730: checking for a BSD-compatible install configure:1785: result: /usr/bin/install -c configure:1796: checking whether build environment is sane configure:1839: result: yes configure:1896: checking for gawk configure:1912: found /usr/bin/gawk configure:1922: result: gawk configure:1932: checking whether make sets $(MAKE) configure:1952: result: yes configure:2112: builddir: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1 configure:2114: srcdir: /export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1 configure:2150: checking build system type configure:2168: result: i686-pc-linux-gnu configure:2196: checking host system type configure:2210: result: i686-pc-linux-gnu configure:2658: checking if want debugging output support configure:2672: result: no configure:2733: checking for gcc configure:2749: found /export/home/heliang/OpenFOAM/linux/gcc-4.1.0/bin/gcc configure:2759: result: gcc configure:3003: checking for C compiler version configure:3006: gcc --version </dev/null>&5 gcc (GCC) 4.1.0 Copyright (C) 2006 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:3009: $? = 0 configure:3011: gcc -v </dev/null>&5 Using built-in specs. Target: i686-pc-linux-gnu Configured with: ../configure --prefix=/usr/tmp/gcc-4.1.0 --exec-prefix=/usr/tmp/gcc-4.1.0 --enable-languages=c,c++ --enable-shared --enable-__cxa_atexit --disable-checking --with-system-zlib Thread model: posix gcc version 4.1.0 configure:3014: $? = 0 configure:3016: gcc -V </dev/null>&5 gcc: '-V' option must have argument configure:3019: $? = 1 configure:3042: checking for C compiler default output file name configure:3045: gcc conftest.c >&5 /usr/bin/ld: unrecognized option '--as-needed' /usr/bin/ld: use the --help option for usage information collect2: ld returned 1 exit status configure:3048: $? = 1 configure: failed program was: | /* confdefs.h. */ | | #define PACKAGE_NAME "" | #define PACKAGE_TARNAME "" | #define PACKAGE_VERSION "" | #define PACKAGE_STRING "" | #define PACKAGE_BUGREPORT "" | #define LAM_MAJOR_VERSION 7 | #define LAM_MINOR_VERSION 1 | #define LAM_RELEASE_VERSION 1 | #define LAM_ALPHA_VERSION 0 | #define LAM_BETA_VERSION 0 | #define LAM_SVN_VERSION 0 | #define LAM_VERSION "7.1.1" | #define LAM_DEPENDENCY_PREFIX "/export/home/heliang/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPO pt" | #define LAM_ARCH "i686-pc-linux-gnu" | #define LAM_WANT_DEBUG 0 | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:3087: error: C compiler cannot create executables See `config.log' for more details. |
CRITICAL ERROR on installation OpenFOAM 141 | nuovodna | OpenFOAM Installation | 19 | March 22, 2010 22:36 |
Critical error | chris_j_meyer | OpenFOAM Installation | 2 | February 13, 2009 02:39 |
Installation problem 1 critical error | Ervin Adorean (Adorean) | OpenFOAM Installation | 14 | October 23, 2006 03:44 |
1 critical error GCC Conflicting installations | atzaru | OpenFOAM Installation | 6 | April 23, 2006 13:50 |
Tow Critical Error about GCC amp icoFoam | chnrdu | OpenFOAM Installation | 4 | July 8, 2005 06:14 |
