Install Openfoam in Suse 100 setup environment |
September 26, 2006, 18:57 |
Hi,folks, please apologize for
Hi,folks, please apologize for my very basic linux knowledge. I have installed the openfoam in my linuz suse 10. I did not know how to setup the environment. This showed the result when i ran the installation test. Can anyone help me please? Thank you
Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux OS: Linux version 2.6.13-15.12-default User: hengky User_config: /home/hengky/.bashrc FATAL ERROR: /home/hengky/.OpenFOAM-1.3/bashrc does not appear to be sourced from: /home/hengky/.bashrc You need the following at the end of your /home/hengky/.bashrc file: . /home/hengky/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc or equivalent depending on the location of the OpenFOAM installation. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/hengky/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.0.2 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java *** not installed *** gzip 1.3.5 /usr/bin/gzip tar 1.3.5 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_linux Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. hengky@linux:~/OpenFoam/OpenFOAM-1.3/bin> |
Canbt install on Suse 102 | klausb | OpenFOAM Bugs | 1 | December 1, 2007 20:05 |
OpenFoam on Suse 101 | varun | OpenFOAM Installation | 0 | November 27, 2007 08:50 |
Installation OpenFoam on SUSE 101 | t42 | OpenFOAM Installation | 1 | August 1, 2007 06:15 |
Installation OpenFoam on SuSe 101 | mephisto | OpenFOAM Installation | 1 | November 8, 2006 02:15 |
global panel and macro / environment setup | guang ai | Siemens | 10 | August 15, 2006 01:13 |
