April 3, 2006, 06:11 |
Hi to all,
I'm new user of li
Giuseppe Noviello
Rep Power: 17 |
Hi to all,
I'm new user of linux o.s. and I am trying to install openFOAM on my pc but when i run foamInstallationTest it report me this: linux:/home/giuseppe/OpenFOAM/OpenFOAM-1.3/bin # bash foamInstallationTest Executing foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux OS: Linux version 2.6.8-24-default User: giuseppe User_config: /root/.bashrc FATAL ERROR: /root/.OpenFOAM-1.3/bashrc does not appear to be sourced from: /root/.bashrc You need the following at the end of your /root/.bashrc file: . /root/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc or equivalent depending on the location of the OpenFOAM installation. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /root/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 3.3.4 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.4.2_11 WARNING: Conflicting installations: foam settings: /usr/lib/jvm/jre/bin/java current path : /usr/bin/java gzip 1.3.5 /bin/gzip tar 1.3.5 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_linux Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. Someone can help me? thanks Giuseppe Noviello |
Problems with installation of OpenFoam | sheyer | OpenFOAM Installation | 8 | July 28, 2008 03:45 |
OpenFOAM installation | Mark | Main CFD Forum | 2 | March 29, 2008 07:45 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 01:40 |
Installation OpenFoam on SuSe 101 | mephisto | OpenFOAM Installation | 1 | November 8, 2006 02:15 |
OpenFOAM installation on AIX 53 with gnu 40 compiler | chauvin | OpenFOAM Installation | 3 | June 15, 2006 13:12 |
