MPICH
Old   June 15, 2005, 12:07
Default Hi, I am trying to install F
Radu Mustata
r2d2 is on a distinguished road
I am trying to install Foam on our beowulf that uses mpich/myrinet.
So I modified some lines in "bashrc" in ".OpenFOAM-1.1":
# export WM_MPLIB=LAM
export WM_MPLIB=MPICH
# SUN workstation
and in the ".bashrc" of "OpenFOAM-1.1" the following lines:
if [ .$WM_MPLIB = .MPICH ]; then
echo 'here--MPICH'
# ..... was.......
# export MPICH_VERSION=1.2.4
# export MPICH_PATH=$FOAM_SRC/mpich-$MPICH_VERSION
# export MPICH_ARCH_PATH=$MPICH_PATH/platforms/$WM_OPTIONS
# export MPICH_ROOT=$MPICH_ARCH_PATH
# ..... end was.......
# ..... new.......
export MPICH_ARCH_PATH=/opt/mpich-1.2.5..11
# ..... end new.......
AddLib $MPICH_ARCH_PATH/lib
AddPath $MPICH_ARCH_PATH/bin
# ..... was.......
# export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/mpich-$MPICH_VERSION
# ..... new.......
export FOAM_MPI_LIBBIN=/opt/mpich-1.2.5..11/lib
AddLib $FOAM_MPI_LIBBIN
...and now every time that I want to do something like "blockMesh . <case>" it complains about the shared library
"blockMesh: error while loading shared libraries: libPstream.so: cannot open shared object file: No such file or directory"
but in mpich-1.2.5..11 I fail to find such libPstream.so. If I add the one from
$FOAM_LIBBIN/lam-7.1.1 it will complain that:
"blockMesh: error while loading shared libraries: libmpi.so.0: cannot open shared object file: No such file or directory"
of course, as I donīt have any libmpi.so
Any ideas? PLease...
Cheers,
Radu
r2d2 is offline   Reply With Quote
Old   June 15, 2005, 19:32
Default The libPstream.so is the OpenF
Mattijs Janssens
mattijs is on a distinguished road
The libPstream.so is the OpenFOAM library that has all the parallel stuff in it. We pre-build the lam-XXX/libPstream.so which gets built by the $FOAM_SRC/Pstream/Allwmake script. Have a look what it does now you have changed your MPI variables.
Anyway you will have to build a libPstream.so that uses your mpich version and then set your LD_LIBRARY_PATH to use that one.
(check with ldd `which blockMesh` to find out what libraries blockMesh is using)
mattijs is offline   Reply With Quote
HOW TO RUN FOAM WITH MPICH waynezw0618 OpenFOAM Running, Solving & CFD 5 May 13, 2009 08:21
PVM or MPICH CFX User CFX 5 November 3, 2004 16:31
LAM/MPI or MPICH? Junseok Kim Main CFD Forum 0 January 15, 2004 07:10
MPICH-Variables James Siemens 4 October 22, 2002 10:14
MPICH Junseok Kim Main CFD Forum 1 November 5, 2000 22:07
