May 2, 2005, 08:09 |
We are planning to upgrad
David Segersson
Rep Power: 17 |
We are planning to upgrade our CFD-hardware, and I just wanted to make sure that it will be possible to run OpenFOAM on the new hardware. Can the binaries provided for Linux/Pentium be expected to work on a machine with two Intel Xeon processors running Red Hat Enterprise Linux ES 3? Regards David |
May 2, 2005, 08:31 |
Probably yes. We're not runnin
Mattijs Janssens
Rep Power: 26 |
Probably yes. We're not running Redhat over here so cannot test.
But you can always recompile from sources. As long as you make sure the gcc compiler you are using is the correct one (3.4.3 for OpenFoam1.1) |
May 2, 2005, 08:45 |
I'm running (according to dmes
Gavin Tabor
Rep Power: 17 |
I'm running (according to dmesg) on twin Intel Xeon 3.06GHz processors under RH8. No problems AFAIK.
Gavin |
Does anyone work with curl in OpenFoam | evgenii | OpenFOAM Running, Solving & CFD | 10 | January 23, 2020 04:14 |
Work anybody with OpenFOAM in Berlin Germany | ingolf | OpenFOAM Running, Solving & CFD | 0 | September 21, 2005 08:27 |
cluster Xeon | Ivan | CFX | 8 | December 7, 2004 16:10 |
PIV Xeon vs. Athlon MP | Clovis R. Maliska Jr. | Main CFD Forum | 1 | March 6, 2002 14:49 |
P3 or P3 Xeon | Scott W | FLUENT | 8 | April 14, 2001 06:08 |
