Tutorial bCavityb case problem
Old   March 20, 2005, 22:02
Default Hi I just installed on SUSE
Paul Wells
wells is on a distinguished road
Hi
I just installed on SUSE 9.1. I edited my .bashrc and sourced. I ran the installation test script and got no errors, but when I try to run the test case 'cavity' I get the following error (from blockMesh). After 'creating blocks' I get 'Illegal Instruction'
Anything obvious?
wells is offline   Reply With Quote
Old   March 21, 2005, 05:13
Default What does ldd `which b
Mattijs Janssens
What does
ldd `which blockMesh`
say. Any libraries in there which come not from under your OpenFOAM installation? Maybe wrong gcc version?
Mattijs
Old   March 21, 2005, 07:55
Default Seems ok. After 'creating bloc
Mattijs Janssens
Seems ok. After 'creating blocks' it should be
Creating patches
so is there anything strange with your patches?
You could try and compile blockMesh with -DFULLDEBUG -g -O0
(add these in Make/options to EXE_INC) and use a debugger.
A question on the first tutorial example bcavityb athlonshi OpenFOAM Running, Solving & CFD 7 October 23, 2008 11:28
Tutorial case lesCavitatingFoam achuneka OpenFOAM Bugs 1 September 25, 2008 13:49
Problem starting a tutorial case alank OpenFOAM Installation 1 December 12, 2006 16:50
Case in Fluent Tutorial 1 Lam FLUENT 0 August 24, 2004 11:25
XiFoam tutorial case pratap OpenFOAM Running, Solving & CFD 1 March 1, 2004 05:25
