I am just trying to install OpenFOAM. The test case runs fine. However I am not able to run PVFOAMReader as it was not able to compile the module, libPVFoamReader.so ./Allwmake: line 2: cmake: command not found make: *** No rule to make target `/home/dm2/henry/OpenFOAM/OpenFOAM-1.0/applications/utilities/postProcessing/graphics/PVFoamReader/PVFoamReader/CMakeLists.txt', needed by `cmake.depends'. Stop. I am not sure what is wrong. Any help is appreciated. Thanks ranjan |
Hi Ranjan,
you need a working cmake and a complete Paraview build to be able to recompile the Paraview reader module. Mattijs |
Chemkin reader | stefanke | OpenFOAM Pre-Processing | 28 | March 8, 2022 10:16 |
[OpenFOAM] ParaFoam reader | duartealbuquerque | ParaView | 21 | December 23, 2009 23:29 |
A reader for cavityOpenFOAM | alex | OpenFOAM Running, Solving & CFD | 11 | April 2, 2009 09:57 |
[OpenFOAM] Reader should I visualize t%3d0 | tj22 | ParaView | 1 | June 30, 2006 10:16 |
New version of Phoenics Reader | Eugene | Phoenics | 0 | December 26, 2002 04:12 |
