Compilation error with PatchToolServer
Old   September 29, 2009, 12:13
Default Compilation error with PatchToolServer
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I am trying to get the OF-1.4 utility patchTool working but I can't seem to get PatchToolServer to compile I get an error about -lssl:
+ cd PatchToolServer
+ wmake
g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/mico-2.3.13/platforms/linuxGccDPOpt/include -I../FoamXServer -I/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/triSurface/lnInclude -I/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/meshTools/lnInclude -I/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/dynamicMesh/lnInclude -IlnInclude -I. -I/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/PatchToolServer.o Make/linuxGccDPOpt/IPatchToolServerImpl.o Make/linuxGccDPOpt/FoamXErrors.o Make/linuxGccDPOpt/LogEntry.o Make/linuxGccDPOpt/LogManager.o Make/linuxGccDPOpt/NameServer.o Make/linuxGccDPOpt/Orb.o Make/linuxGccDPOpt/Paths.o -L/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linuxGccDPOpt \
-L/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/mico-2.3.13/platforms/linuxGccDPOpt/lib -lmicocoss2.3.13 -lmico2.3.13 -lssl -lcrypto -ldl -lPatchToolServer -ltriSurface -ldynamicMesh -lmeshTools -lOpenFOAM -ldl -lm -o /home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/linuxGccDPOpt/PatchToolServer
/usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld: cannot find -lssl
collect2: ld returned 1 exit status
make: *** [/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/applications/bin/linuxGccDPOpt/PatchToolServer] Error 1
At the moment, I can get the patchTool GUI to open but I cannot load a case as it says the PatchToolServer is not running.
I'm not sure if it is connected but when I was recompiling OpenFOAM-1.4.1-dev, some of the solvers and libraries didn't compile and gave the error about ‘yyFlexLexer’.
+ wmake libso triSurface
Making dependency list for source file triSurface/interfaces/STL/readSTLASCII.L
SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; foamFlex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGccDPOpt/readSTLASCII.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/philipc/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/readSTLASCII.C -o Make/linuxGccDPOpt/readSTLASCII.o
triSurface/interfaces/STL/readSTLASCII.L:55: error: no ‘int yyFlexLexer::yywrap()’ member function declared in class ‘yyFlexLexer’
I found this mentioned on the forums but there was no real solution given and the things suggested didn't work for me (changes in readSTLASCII.L file).
I would be very happy if anyone could give me hints on how to get PatchToolServer to compile or explain anything about '-lssl'. I have tried a few things like updating mico but to no avail, hopefully someone can help.
Philip
bigphil is offline   Reply With Quote
Old   September 29, 2009, 13:21
Default fixed!
bigphil's Avatar
Philip Cardiff
PHEW got it working!
I don't really know what the problem was but since I thought it was some missing package on my OpenSUSE 11.0, I checked looked at other compilation errors on the forum and packages that needed to be installed, so I installed a few through YaST2 and then PatchToolServer compiled!
The packages I installed were the following:
binutils
binutils-devel
bison
qt3-devel
I think it is one of these.
BTW I realise I only posted the question an hour ago, I actually thought I posted it yesterday but I must have only previewed it.
A happy Philip
Last edited by bigphil; September 29, 2009 at 13:26. Reason: I left out binutils-devel
UDF compilation problem on Linux System Nitin Pathak Fluent UDF and Scheme Programming 6 September 29, 2018 20:26
Compilation Error when running Tutorial 2.4 zhihuali Siemens 7 April 1, 2008 07:34
Compilation error with uparm.f Raghu Siemens 2 May 30, 2007 02:09
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
Need help on double precision compilation tingguang Main CFD Forum 1 March 18, 2002 17:26
