Problems in compiling solvers when using OpenFOAM13_11092006
Old   June 7, 2008, 06:10
Default Hi everyone, I am using OF-
jin xu
jin_xu is on a distinguished road
Hi everyone,
I am using OF-1.3 and my OS is ubuntu 7.10. the OF-1.3 in my machine is working perfectly.
To use the FSI solver(icoFsiFoam), I download OpenFOAM-1.3_11092006 and extract it in the ~/OpenFOAM to replace the one used before(which is from OpenFOAM-1.3.General). At this moment, I can still compile the icoFsiFoam solver but I can not run a case for it as I need to rebuild everything(I find this method on the discussions about the balloon case),so I use ./AllMake in the main directory to
build everything(there is no error in this process). at the moment the re-build is done, I type "which g++" in the terminal, it is the one provided by OF, but when I close the terminal and re-open it, then again, I type"which g++", I get:/usr/bin/g++, and when I try to compile the modified icoFsiFoam solver, I get one error:
/usr/bin/ld: cannot find -liberty
I have read some posts in the board, and realise that if "which g++" give you the one provided by OpenFoam, this error will not appear.
so the problem confusing me is that why the enviroment variable is changed after I just replace the orginal OpenFOAM 1.3 directory and rebuild everything and I can not use the g++(or gcc) provided by OF
To find a way around it, I try to follow the buildinstructions in the website for an OF-dev, but I run into some problems:
(1) now I do not need run OF in paralle, do I need to install everything recommended in the website
(2) when I try to use "gmake", I was told this commond is not found, but intead I use "make", is that right?
(3) when I try to type "make install", I was told somthing like "permission denied when creat directory ...usr/tmp.....".
I am just getting started with OF and Linux,and some questions may sound very stupid, Could anyone pleae give me some hints on how to use/build the OpenFOAM-1.3_11092006 correctly
I will really appreciate your help!
jin
jin_xu is offline   Reply With Quote
Old   June 7, 2008, 06:17
Default My machine is 32 bit regard
jin xu
regards
Old   June 9, 2008, 11:25
Default Hi Jin! I think it is written
Assistant Moderator
Bernhard Gschaider
Hi Jin!
I think it is written somewhere else on the Board: libiberty.a is provided by some rather "esoteric" packages on some distros and therefor not always present.
On my machines (RHEL/CentOS 5.x) it is provided by binutils-devel. On these distros I find out who provides this with the command "yum provides libiberty". What the equivalent command on Ubuntu would be: I don't know
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 11, 2008, 08:07
Default In Ubuntu it is: apt-cache
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
In Ubuntu it is:
apt-cache search libiberty
It gives nothing in my Kubuntu 7.10
Regards
Paulo
paulo is offline   Reply With Quote
Old   June 11, 2008, 08:10
Default I've read all the messages and
I've read all the messages and now foud the result of:
paulo@SEM:~$ apt-cache search liberty
liblasso-java - Liberty ID-FF library - Java bindings
liblasso3 - Liberty ID-FF library - runtime library
liblasso3-dev - Liberty ID-FF library - development kit
python-lasso - Liberty ID-FF library - Python bindings
So maybe installing the liblasso3 package helps.
Regards
Paulo
Old   June 18, 2008, 17:24
Default Hi Paulo I fix this problem
feng wang
fw407 is on a distinguished road
Hi Paulo
I fix this problem by installing binutils-devel.
Kind regards
feng
fw407 is offline   Reply With Quote
Old   July 2, 2010, 12:34
Default /usr/bin/ld: cannot find -liberty
Shoonya is on a distinguished road
yes that worked in ubuntu 10.04 too, when I was intalling OpenFOAM-1.7.0
when I did
$ ./Allwmake
collect2: ld returned 1 exit status
I installed
$ sudo apt-get install binutils-dev
that solved my problem ...and I was able to compile
thank you
dinesh
IIT Kanpur
Shoonya is offline   Reply With Quote
[OpenFOAM.com] Compiling problems chris1980 OpenFOAM Installation 8 June 3, 2015 15:41
Problems about solvers fw407 OpenFOAM Running, Solving & CFD 17 March 5, 2009 07:29
Problems with compiling roberthino OpenFOAM Installation 3 March 17, 2008 04:04
Problems while compiling source sahas OpenFOAM Installation 2 October 20, 2007 12:47
Problems compiling under 14 grtabor OpenFOAM Running, Solving & CFD 9 July 17, 2007 22:34
