OpenFoam1.6 Installation in Ubuntu9.10
Old   January 1, 2010, 09:47
Default OpenFoam1.6 Installation in Ubuntu9.10
mohanvelin's Avatar
Mohanavelu Palaniswamy
mohanvelin is on a distinguished road
I have run the foamInstallationTest, I have got 1 critical error regarding gcc version mismatch . I like to know how to overcome the critical error.
Executing /home/mohanavelu/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               mohanavelu-laptop
OS:                 Linux version 2.6.31-16-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/mohanavelu/OpenFOAM                yes       yes
$WM_PROJECT_USER_DIR /home/mohanavelu/OpenFOAM/mohanavelu-1.6  no        no
$WM_THIRD_PARTY_DIR  /home/mohanavelu/OpenFOAM/ThirdParty-1.6  yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/mohanavelu/OpenFOAM/OpenFOAM-1.6   yes  yes  yes
$FOAM_APPBIN         ...M-1.6/applications/bin/linuxGccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    .../OpenFOAM/site/1.6/bin/linuxGccDPOpt  no        no
$FOAM_USER_APPBIN    ...u-1.6/applications/bin/linuxGccDPOpt  no        no
$WM_DIR              ...hanavelu/OpenFOAM/OpenFOAM-1.6/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...nFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    .../OpenFOAM/site/1.6/lib/linuxGccDPOpt  no        no
$FOAM_USER_LIBBIN    ...OAM/mohanavelu-1.6/lib/linuxGccDPOpt  no        no
$MPI_ARCH_PATH       ...penmpi-1.3.3/platforms/linuxGccDPOpt  yes  yes  yes
Third party software
Software Version   Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
         Supplied version: 4.3.3
         User version    : 4.4.1
         Minimum required: 4.3.1
gcc      4.4.1
WARNING:  Conflicting installations:
          OpenFOAM settings        : /bin/gcc
          current path             : /usr/bin/gcc
          CRITICAL ERROR
gzip     1.3.12    /bin/gzip
tar      1.22      /bin/tar
Aborted
icoFoam  1.6       ...AM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/icoFoam
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
mohanvelin is offline   Reply With Quote
Old   January 2, 2010, 05:51
Tamás Baksa
tamas.baksa.hu is on a distinguished road
I am on openSuse 11.2 but have the same problem
I had an other problem described in an other thread here
so I set the compilerInstall=System (line 98 in file /.../OpenFOAM-1.6/etc/settings.sh) based on recommendation by grig
after that foamInstallationTest gives the error you have
so you could try to set compilerInstall=OpenFOAM and try whether foamInstallationTest and any application that uses gcc (kde, gnuplot) can run as well
tamas.baksa.hu is offline   Reply With Quote
Old   January 2, 2010, 10:58
Default OpenFOAM Installation
mohanvelin's Avatar
Sir, I have made changes as proposed by you in two file
/OpenFOAM-1.6/etc/setting.sh
as well as
/OpenFOAM-1.6/etc/setting.csh
openfoam 1.6
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
