install gcc
Old   March 28, 2010, 14:46
Default install gcc
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
i try to install gcc-4.3.3 it asked me to specifythe path of gmp.h and mpfr.h
how can i do this in one command.
thanks.
Ahmed Khattab is offline   Reply With Quote
Old   March 28, 2010, 17:28
Retired Super Moderator
Bruno Santos
Greetings ahmed,
My guess is that happened to you, after managing to get makeGcc to work properly
OK, by my estimate, the problem you're having now is due to 3 missing files in mpfr that comes with the Third Party General package. See this post #13, where I've already made available a patch for creating the missing 3 files. Instructions on how to apply it are on that same post
After that, try again the makeGcc command.
Best regards,
Bruno
PS: you could have continued to use your previous thread
Old   March 29, 2010, 05:17
Default this is not the problem
ahmed
first thank you for your interest
i have already downloaded the whole compressed file and extract it it works good until the installation of mpfr-4.2.1. but when i try to install gcc-4.3.3 it ask me to specify the place pf gmo.h and mpfr.h so i type:
$ /home/ahmed/OpenFOAM/ThirdPArty-1.6/gcc-4.3.3/configure --with-gmp-include=/home/ahmed --with-mpfr-include=/home/ahmed/OpenFOAM/ThirdParty-1.6/mpfr-4.2.1
it say correct version of mpg ------ yes
correct version of mpfr-------no
i tried /usr/local directory
i tried /home/ahmed directory
i tried --with-mpfr
i tried --with mpfr-build
Old   March 29, 2010, 18:17
Bruno Santos
Greetings Ahmed,
OK, you can make your life easier if you run:
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc
cd $WM_THIRD_PARTY_DIR
./makeGcc gcc-4.3.3 2>&1 | tee make.log
These three lines will: setup the OpenFOAM environment; go to the ThirdParty folder; and build gcc-4.3.3, while showing the output on screen, as well as putting what you see on screen into the file make.log.
Now, IF you still want to do everything by hand, then to simplify your efforts, type the following two lines:
ln -s $WM_THIRD_PARTY_DIR/gmp-4.2.4 $WM_THIRD_PARTY_DIR/gcc-4.3.3/gmp
ln -s $WM_THIRD_PARTY_DIR/mpfr-2.4.1 $WM_THIRD_PARTY_DIR/gcc-4.3.3/mpfr
Then compile gcc using:
cd $WM_THIRD_PARTY_DIR/gcc-4.3.3
mkdir build
cd build
../configure --enable-languages=c,c++ --with-pkgversion='OpenFOAM' --enable-__cxa_atexit --enable-libstdcxx-allocator=new --with-system-zlib --prefix=$WM_THIRD_PARTY_DIR/gcc-4.3.3/platforms/$WM_ARCH
For those variables that start with a '$' you'll need to setup OpenFOAM's environment, by running that first line at the top, the one with bashrc.
Best regards,
Bruno
Old   March 30, 2010, 11:18
Default is the gcc was installed
ahmed
thank you very much when i followed your advice it wrote that
gmp is already built
mpfr is already built
gcc is already built
Old   March 30, 2010, 11:31
Bruno Santos
Greetings Ahmed,
If it wrote that in only a few seconds, that's because you've unpacked the binary packages of the ThirdParty (namely ThirdParty-1.6.linux*Gcc.gtgz).
To force the rebuilding of gmp+mpfr+gcc, you'll have to remove the contents inside the "platforms" folders that exist inside each folder. You can do that by running:
rm -rfi $WM_THIRD_PARTY_DIR/gmp-4.2.4/platforms/$WM_ARCH$WM_COMPILER_ARCH
rm -rfi $WM_THIRD_PARTY_DIR/mpfr-2.4.1/platforms/$WM_ARCH$WM_COMPILER_ARCH
rm -rfi $WM_THIRD_PARTY_DIR/gcc-4.3.3/platforms/$WM_ARCH$WM_COMPILER_ARCH
Then try again to build gcc et al. It should take about 20 to 60 minutes to complete the whole task, depending on the machine you have.
Best regards,
Bruno
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
install gcc Ahmed Khattab OpenFOAM 1 March 16, 2010 18:15
Question on specify gcc compiler for OpenFOAM 15 peterlai OpenFOAM Installation 2 October 2, 2008 07:20
Gcc conflict install inddzen OpenFOAM Installation 2 December 11, 2007 16:00
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
