OpenFOAM-1.5-dev - missing Hasher.H
Old   August 2, 2010, 10:23
Default OpenFOAM-1.5-dev - missing Hasher.H
luiz eduardo b. sampaio
luizebs is on a distinguished road
Dear All,
I am trying to install the dev version, but I got a message saying
+ wmake libso dummy
make: *** No rule to make target `/home/luizebs/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/Hasher.H', needed by `OPwrite.dep'. Stop.
+ case "$WM_MPLIB" in
+ set +x
+ WM_OPTIONS=linux64GccDPOptOPENMPI
In fact, there was no such file in the dir.
I am up to date with revision 1806, so I should be fine.
Can someone please help?
Best regards,
luiz
luizebs is offline   Reply With Quote
Old   August 3, 2010, 07:16
astein is on a distinguished road
The files in "lnInclude"-folders should be generated/linked by wmake itself. The file is not supposed to be existent right after the checkout. So, something went wrong with the linking. Try a "wclean" or "wclean all" do wmake again.
Did you run the "Allwmake" in the main source folder? That script should do all you need after a fresh checkout.
-Andreas.
astein is offline   Reply With Quote
[OpenFOAM] ParaFoam instalation in OpenFoam 1.5 dev titio ParaView 2 July 24, 2010 23:24
OpenFOAM 1.5 dev LVDH OpenFOAM 98 May 5, 2010 17:01
[OpenFOAM] ParaView/ParaFoam in OpenFoam 1.5 dev titio ParaView 2 February 27, 2010 14:02
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 12:12
