Dear All
Old   August 31, 2010, 03:23
Default Dear All
Kurne
kurne is on a distinguished road
I am facing the problem with the installation of OpenFOAM 1.7.1. I have gone up to the step of extracting the file but I am unable to Setting environment variables.
I have gone through the procedure but i am getting the following error.
Error: Current directory is not $WM_PROJECT_DIR
The environment variable are not consistent with the installation.
Check the OpenFOAM entries in your dot-files and source them
Will anybody explain the procedure of Setting environment variables once to me(Step by Step) since i am not getting it.HELP ME PLEASE I AM TRYING FOR IT FROM A WEEK.
kurne is offline   Reply With Quote
Old   August 31, 2010, 04:01
val46 is on a distinguished road
what linux distribution do you have?
What happens if you type
cd $WM_PROJECT_DIR
Regards,
Toni
val46 is offline   Reply With Quote
Old   August 31, 2010, 06:53
Retired Super Moderator
Bruno Santos
Greetings to all! And kurne, welcome to the forum
In addition to Toni's question, I've got a few more questions:
  • What Linux distribution are you using? And is it 32 or 64bit?
  • In what folder did you install OpenFOAM? Was it "$HOME/OpenFOAM"? Does "$HOME/OpenFOAM" have the folders OpenFOAM-1.7.1 and ThirdParty-1.7.1?
  • What does it look like in the end of the file "$HOME/.bashrc"? I'm asking you this, because I don't if you've already tried to install any other version of OpenFOAM, and/or if the file "$HOME/.bashrc" is actually working well or not.
Best regards,
Bruno
Old   September 1, 2010, 00:19
Default OPEN FOAM INSTALlATION
Kurne
Thanks a lot for replying Toni and Bruno.I am new to the open FOAM & Ubuntu too.I am trying to install with root login and I am unable understand the procedure of installation given in the OPENFOAM website.Now I am starting the new installation will anybody explain the procedure in other way to me.In the previuos installation i have done lot of mistake.
Best Regards,
Kurne
Old   September 1, 2010, 05:26
Gijsbert Wierink
gwierink is on a distinguished road
Hi Kurne,
In addition to the above, I think it is not a good idea to install OpenFOAM as root. It would be better to login as your own user.
Also, are you unpacking "standard packages" from OpenCFD or compiling?
Regards, Gijs
gwierink is offline   Reply With Quote
Old   September 1, 2010, 05:28
Hi Kurne,
my guess is you are using Ubuntu 10.04.
For this version a step-by-step installation guide exists:
http://www.openfoam.com/download/ubuntu.php
If you have problems with it let us know at which point you get stuck.
Regards,
Toni
Old   September 1, 2010, 14:01
Default Oepn foam installation
Kurne
Thank You ALL
I have started new installation and I get up to the ./Allwmake.When I am running ./Allwmake I am getting the following error but installation is going on.
make: *** [/home/azim/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libutilityFunctionObjects.so] Error 1
make: *** [/home/azim/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libsystemCall.so] Error 1
make: *** [/home/azim/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libconversion.so] Error 1
and So on.
How much it will take time to run the ./Allwmake my this run is running from the 1 hr and getting the above error.
Will it will create the problem when i am run the OpenFOAM .
Will anybody help me.
Best Regards
Kurne
Old   September 1, 2010, 14:09
Kurne
Thank You ALL
and So on.
Best Regards
Kurne
Old   September 1, 2010, 17:36
Bruno Santos
Greetings Kurne,
OK, installing from source in Ubuntu, before you start compiling, you need to install the packages listed on this post: http://www.cfd-online.com/Forums/ope...tml#post268828
After that, it should be as simple as following the instructions in http://www.openfoam.com/download/source.php
Best regards,
Bruno
Dear Professors -Trainning in CFD- under boycast scheme mani1496 Main CFD Forum 0 October 26, 2009 03:06
Dear Members Dr.K.Thiruvenkatasamy Main CFD Forum 1 June 23, 2007 12:52
Dear Jonas, it seems to me We have a small problem Michail CFD-Wiki 3 December 10, 2005 17:43
i want to find my dear friend ... kevin FLUENT 0 February 28, 2002 20:15
Find a my dear friend ..... kevin FLUENT 0 February 25, 2002 21:28
