#1 | |
Rep Power: 15 ![]() |
I just installed openfoam how it's written in the manual.
Now i have a problem to continue with the "getting started" part. Quote:
and to write mkdir -p $FOAM_RUN in the terminal leads to nothing. ![]() plz help |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings Guardian and welcome to the forum!
Try running the following two commands: Code:
echo $HOME echo $FOAM_RUN The first one should show your own user folder in the "/home" folder; For example "/home/guardian". The second one should show something like "/home/guardian/OpenFOAM/guardian-1.7.1/run". If it doesn't, it's because OpenFOAM isn't properly installed. If it does show something, try running this: Code:
cd $FOAM_RUN ![]() Code:
mkdir: missing operand Try `mkdir --help' for more information. Code:
export env Code:
env --help man env Bruno
It wouldn't be a problem at all to create these directories with the file manager.
I just thought that i have to create them by using the mkdir command. so i was just confused that it didn't work. Now i copied the tutorials into the run directory and started it with the commands: cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity blockMesh icoFoam paraFoam ...then paraview opened. but where the hell is openfoam? ![]() |
Bruno Santos
Hi Guardian,
ParaView is used for post-processing: http://www.openfoam.com/docs/user/ca...#x5-130002.1.4 OpenFOAM did it's magic when you ran: Code:
blockMesh icoFoam Bruno
Bruno Santos
Hi Guardian,
Nope, sadly FoamX is no longer supported nor developed AFAIK. For more information, you can read about it here. Best regards, Bruno
The fluent process could not be started | Mary | FLUENT | 5 | June 23, 2017 07:38 |
Error: Fluent process could not be started | Clem | FLUENT | 1 | November 26, 2015 13:23 |
Help getting started | Xye | OpenFOAM | 1 | November 21, 2009 14:01 |
EOF on stderr. the fluent could not be started | sree_rahul | FLUENT | 2 | July 12, 2006 06:59 |
HELP-error: the fluent process cannot be started | James Willie | FLUENT | 0 | January 24, 2006 11:17 |
