Intstalling the Source Pack of OpenFOAM 1.7.1
Old   July 8, 2011, 14:08
Default Intstalling the Source Pack of OpenFOAM 1.7.1
Walter Schostak
wschosta is on a distinguished road
I'm trying to install the source pack of OpenFOAM 1.7.1 on a server location where I don't have access to the .cshrc file (I'm using csh).
So I follow the instructions (http://www.openfoam.com/archive/1.7....oad/source.php) as best I can but once I run the ./Allwmake and it finishes I run the ./foamInstallationCheck and it returns this:
Executing ./foamInstallationTest:
Checking basic setup...
FATAL ERROR: OpenFOAM environment not configured.
    Please refer to the installation section of the README file:
    <OpenFOAM installation dir>/OpenFOAM-1.7.1/README
    to source the OpenFOAM environment.
But as far as I can tell I've set the environment variables correctly and I don't see any other way to set them then the way defined in the installation instructions.
Any suggestions?
wschosta is offline   Reply With Quote
Old   July 9, 2011, 05:41
Retired Super Moderator
Bruno Santos
Greetings Walter,
You don't have access? The file should be in your home folder! Namely "$HOME/.cshrc". Now, it's a whole other issue if the $HOME variable is undefined. To check this by running:
echo $HOME
If it outputs nothing, then this is what's going wrong with your installation.
Allwmake should have complained in the same way as foamInstallationCheck! You should have seen a million error messages!
You could have said how exactly you set those variables. It would be a lot easier for us to figure out what happened
Best regards,
Bruno
Using source term in OpenFOAM user369 OpenFOAM 13 August 7, 2011 08:51
Error in apt-get update for installation of OpenFoam 1.7.1 on Ubuntu 10.10 StuntedChicken OpenFOAM Installation 1 January 9, 2011 10:43
RPM packages of OpenFOAM 1.7.1 for CentOS vnpenguin OpenFOAM Installation 0 November 14, 2010 12:51
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
