Tutorial files
Old   March 2, 2012, 08:31
Default Tutorial files
FZ
bookchangerII is on a distinguished road
hi everyone,
I've just installed Openfoam 2.1.0 and Paraview and I would like do the tutorials. Unfortunately I cant find the files. There should appear an folder called Openfoam in my home directory but there is none. I'm quite sure the installation of openfoam was succesful. Do I have to install them seperately or how can I find them?
thanks
bookie
bookchangerII is offline   Reply With Quote
Old   March 2, 2012, 08:50
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hihi,
if you installed everything according to the website the alias "run" should work!
open a terminal and type : run
it will take you to a folder with the tutorials folder in it.. then you just enter it and run the well known cavity tutorial..
if you prefer: cd $FOAM RUN/tutorials/incompressible/icoFoam/cavity
check this link: http://www.openfoam.org/docs/user/cavity.php#x5-40002.1
it's the walkthrough of the lid-driven-cavity
also type: which icoFoam
and you see where OF was installed!
/calim
calim_cfd is offline   Reply With Quote
Old   March 2, 2012, 08:54
FZ
hi calim,
thanks to your reply
"run" didnt work, but I found out that openfoam was installed in /opt/ . thank you very much
Tutorial Hemida for OF-1.6 flowris OpenFOAM 11 August 26, 2013 15:07
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Fluent6.3 Tutorial files Ali Doustdar FLUENT 3 December 23, 2010 08:54
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Fluent Tutorial 18 BC's J. Weiler FLUENT 1 April 26, 2001 15:17
