Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Journal
Alletto - 2022 - Comparison of overset mesh with morphing mesh
Like Tree9Likes
Old   February 18, 2022, 16:22
Alvi Ahmmed
Alvi is on a distinguished road
Thank you very much. I can get the natural frequency(fn) from St=fnD/U equation right? And am I free to choose U and D for a fixed Re=100?
Alvi is offline   Reply With Quote
Old   February 18, 2022, 17:14
Michael Alletto
mAlletto will become famous soon enough
You can choose the parameters as you want as long all dimensional less parameters are the same. The frequency in the st number is the shedding frequency not the natural frequency
mAlletto is offline   Reply With Quote
Old   February 19, 2022, 01:54
Alvi Ahmmed
How can I find the value of natural frequency (fn) ? From the FFT plot of the lift coff? Regards.
Old   February 19, 2022, 02:05
Michael Alletto
See https://en.m.wikipedia.org/wiki/Natural_frequency
For the natural frequency of a spring mass system. But I think I mentioned this also in the paper. Read it carefully.
What is done in the python scripts is also explained in the paper. A fft of the lift signal is performed and the maximum amplitude is used to calculate the St number. Read the paper a few times if once is not enough.
I usually need three or four times to fully understand a paper
Tianyz likes this.
Old   February 19, 2022, 02:08
Alvi Ahmmed
Thanks very much for your guidence
Old   March 22, 2022, 01:44
Default How to set the density in the VIV case
  #26
Mehdi Badri
Mehdi80 is on a distinguished road
According to the definition of non-dimensional mass, m^{\ast}, on page 18 of your paper, the density of the cylinder, \rho, is calculated as \rho= 4*m / ( m^{\ast}  d^{2} H ).
In your paper (and its corresponding git repo), you have used \rho=14817, whereas it seems that if we substitute m=03575, H=0.12, m^{\ast}=10, and d=0.0016, the density should be \rho=46549.
Could you please clarify how you calculated it (and why my understanding is perhaps incorrect)?
Mehdi80 is offline   Reply With Quote
Old   March 22, 2022, 03:16
Michael Alletto
Hello.
I just found a typo in how the fluid density is calculated. The non dimensional mass m*
is defined as follows in the paper:
m^* = \frac{m}{m_f} = \frac{4 m}{\rho D^2 H}
Unfortunately I forgot the pi. It should have been
m^* = \frac{m}{m_f} = \frac{4 m}{\pi \rho D^2 H} = 10
With the second formula we obtain the value of the fluid density specified in the paper
Mehdi80 likes this.
Old   March 22, 2022, 19:58
Thumbs up Thank you
  #28
Mehdi Badri
Originally Posted by mAlletto View Post
Hello.
That is a nice explanation and helpful note!
Thanks
Old   March 22, 2022, 23:21
zink
ansab_sindhu is on a distinguished road
It was missing in the formula but the calculation of the density is the correct in the tables and paragraphs.
Thanks
ansab_sindhu is offline   Reply With Quote
Old   April 5, 2022, 11:12
Default citation
  #30
Wael Elorfi
welorfi is on a distinguished road
Is there a bibtex file available for citing this paper?
welorfi is offline   Reply With Quote
Old   April 5, 2022, 11:34
Smile
  #31
Michael Alletto
I usually copy the bibtex entry from Google scholar
welorfi likes this.
Old   April 5, 2022, 13:40
Default citation
  #32
Wael Elorfi
Got it. Thanks a lot!
@article{alletto2022comparison, title={Comparison of overset mesh with morphing mesh: Flow over a forced oscillating and freely oscillating 2D cylinder}, author={Alletto, Michael}, journal={OpenFOAM{\textregistered} Journal}, volume={2}, pages={13--30}, year={2022} }
Old   April 11, 2022, 05:15
Default Doi
  #33
Håkan Nilsson
hani is on a distinguished road
This paper has now been updated with the ISSN of the journal and its own DOI: https://doi.org/10.51560/ofj.v2.47
welorfi likes this.
hani is offline   Reply With Quote
Old   July 7, 2022, 12:42
zink
Can anyone explain the m in this equation? Is it only the mass of the cylinder?
Does this include the added mass as well?
U* = Uoo/(fn D) , fn = ω/(2 π) = (k / m)0.5/(2 π)
So if you want to achieve a given U* for a given diameter of the cylinder with a given mass and inflow velocity you have to set k accordingly.
Hope this helps
Old   July 8, 2022, 06:45
Michael Alletto
It's only the mass of the cylinder
Old   July 8, 2022, 13:46
zink
I need some clarification regarding your paper
Q-1:
You have mentioned that
density of the cylinder is set to 14817 kg/mˆ3. It should be called as the density of the fluid not the cylinder?
Q-2:
In your calculations, in the case of Ur 4, you have used the k = m*(2*pi*f)ˆ2 that gives k value of 148.28.
I want to ask about the f used in the calculation. We know that the reduced natural frequency of the system is given as Fr = I/Ur and Ur= Unif/f*D , here f is the frequency in the flow medium . It could be air, water or any medium used in the simulation. In the present case, it is the frequency in the fluid having density 14817 kg.m3.
f= 0.0656/(4*0.0016) = 10.25
As you are using cylinder mass m=0.03575 ,then the k should be calculated as
k=(m+m_added_mass)*(2*pi*f)ˆ2
m_added_mass= C_EA*(pi*Dˆ2*H*rhoInf/4) =0.003575
k=163.108
Please clarify? I just want to learn that how f is related with k when you are using medium other than air. Should it include the added mass or not?
Old   July 9, 2022, 03:35
Michael Alletto
Q1: It is the density of the cylinder. If you fix the mass and the dimensions of the cylinder the density can be calculated
Q2: The added mass is not considered. It is actually not known in advance since it is solution dependent. What did you mean with added mass exactly. Can you specify it more precisely?
The purpose of setting the constants in the paper in the way I did it, is to match all relevant non-dimensional constants. This are U*, m* and Re. Actually you can choose all combination of dimensional quantities as you want as long as the non-dimensional quantities remain the same. If the non-dimensional quantities are the same you can compare the non-dimensional solutions.
Have a look at the pi-theorem https://en.wikipedia.org/wiki/Buckingham_%CF%80_theorem
Best
Michael
Old   April 12, 2023, 11:12
Manchester
Tianyz is on a distinguished road
Originally Posted by hani View Post
Comments and questions are welcomed on the article Alletto, Comparison of overset mesh with morphing mesh: Flow over a forced oscillating and freely oscillating 2D cylinder, OpenFOAM Journal, January 2022, https://doi.org/10.51560/ofj.v2.47.
Hi Michael,
Many thanks for your contribution, one quick question is about overset mesh, for interpolation fringe, it's better to walk away from the cylinder boundary to avoid a huge gradient, is it right? When using overset mesh for your case, have you ever faced the issue at the interface between the overset component and background component? I mean the velocity and pressure field at this interface are not consistent, I think that's due to the issue about mass conservation, can we improve this phenomenon by adjusting the interpolation scheme?
Tianyz is offline   Reply With Quote
Old   April 12, 2023, 15:07
Michael Alletto
yes better avoid regions of strong gradients where to place the overset boundary.
Best
Michael
Old   May 13, 2023, 13:41
Smile About fvSchemes
  #40
Manchester
Is someone is interested the case files of the paper can be found here https://gitlab.com/mAlletto/openfoam...ases4PaperSend
Hi Michael,
Thank you for your sharing, which helps me a lot.
I noticed you used cubic for div(phi, U) term instead of other second-order discretization schemes. I tried linearUpwind, QUICK, and cubic, and the results changed a lot, actually for the overset mesh, linearUpind predicts the highest frequency of lift coefficient, but the cubic returns the highest amplitude and reasonable frequency. Can you please explain why, is there any useful reference to support it?
Best,
Tian
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 22:35
Overset: refine background mesh without resetting the mesh JohnAB STAR-CCM+ 6 May 19, 2014 13:48
Help in setting up an overset mesh RKE STAR-CCM+ 1 February 21, 2014 21:35
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
