[Sponsors] | |||||
Barestrand et al. - 2023 - Modeling Convective Heat Transfer of Air in a Data... |
Miguel Nóbrega
Rep Power: 15 ![]() |
Comments and questions are welcomed on the article Barestrand et al., Modeling Convective Heat Transfer of Air in a Data Center Using OpenFOAM: Evaluation of the Boussinesq Buoyancy, OpenFOAM Journal, https://doi.org/10.51560/ofj.v3.59.
Charles
Rep Power: 11 ![]() |
Thanks for the paper. Can you elaborate "An opening is therefore made in the geometry to act as a pressure reference to alleviate this, enabling the use of a specified flow rate for the CRAH-return areas."? Is this opening the supply area (grey)?
Charles L. |
Henrik
Hi Marpole,
The pressure opening acts as a sort of reference, indirectly modelling that the data center is not airtight towards the atmosphere. Here it is done by making a small 10x10 cm hole with a simple pressure boundary condition. The effect on the stiffness of the CFD solution is substantial in how it improves convergence due to the other boundaries using enforced mass flows to preserve continuity across racks. /Henrik |
milo cheung
Rep Power: 4 ![]() |
Hi everyone, I am really appreciate this paper, and also provided the case files. Unfortunately, I've encountered some issues while attempting to run the "steady_incompressible" case, which has brought my progress to a halt. The detail error file also attached. It will be nice if anyone can help. Thank you very much.
Here's my setting and changes. use finest grid no changes,"40mm, UUF" that oneCopy and run the commands from "Allrun" file. nmesh=16 Error when I run "renumberMesh".No problem when I pass "--oversubscribe" option in every mpirun. command:Error when I run "buoyantBoussinesqSimpleFoam" command: __________________ Milo Last edited by milocheung; January 8, 2024 at 21:48. |
Charles
As you can read from the error message "error message: There are not enough slots available in the system to satisfy the 16", the program asks for using 16 CPU and your computer might have less than 16 CPU.
Charles L. |
milo cheung
Hi Marpole,
Thank you for your reply. Apologies for the confusion due to the unclear typesetting; I have two distinct issues to address. For the first issue regarding MPI, I believe I've found a potential solution. I'm considering using the "oversubscribe" option with the mpirun command, which seems appropriate given my computer's specs: an AMD Ryzen™ 9 7940HS Processor featuring 8 cores and 16 threads. This should allow me to utilize all available threads even if the number of processes exceeds the number of physical cores. Regarding the second problem, I encountered a "Floating point exception" error while running buoyantBoussinesqSimpleFoam. Any idea for it? __________________ Milo |
Charles
Hi Milo,
The second error is obviously a divergence error as you can see the residual of epsilon, k and the error of continuity. When reading the max/min U from the log, they are way large (e.g. 295,721m/s at time step 2). This can be caused by a number of reasons. But I would review mesh and mesh quality first (file log1_check).
Charles L. |
milo cheung
Hi Marpole,
File uploaded. Thank you. |
#9 |
Charles
The mesh quality is Okay. Can you display your decomposeParDict?
Charles L. |
#10 |
milo cheung
Hi Marpole,
I pass "system/meshParDict" in "-decomposeParDict" option in following commands: decomposePar -decomposeParDict system/meshParDict | tee logs/log1_decomposesystem/meshParDict content Code:
FoamFile
class dictionary;
format ascii;
object decomposeParDict;
version 2.0;
numberOfSubdomains 16;
method scotch;
FoamFile
class dictionary;
format ascii;
version 2.0;
numberOfSubdomains 88;
method metis;
coeffs
n (4 4 6);
The log1_decompose, log1_rnM, log1_snappy file also uploaded. Thank you. __________________ Milo |
#11 |
milo cheung
I can execute the case files now. I downgrade the swak4Foam to v2021.05, and ubuntu from 22.04 to 20.04. Then I am able to run the cases. I think the ubuntu version is the main reason. Thank you. __________________ Milo |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
| Moist air condensation modeling for heat exchanger | rdp5252 | Fluent Multiphase | 0 | November 18, 2021 15:43 |
| Heat transfer between wall and air in Fluent | jimmy871013 | FLUENT | 6 | April 27, 2018 03:00 |
| Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
| No heat transfer in air | thomasyangfly | CFX | 1 | April 18, 2013 07:35 |
