[blockMesh] A simple problem about blockMesh
Old   September 29, 2012, 08:12
Exclamation A simple problem about blockMesh
Dongyue Li
sharonyue is on a distinguished road
hi guys:
This is my blockmeshdict. its very sparse. but when Im revising the code in red below. There is an error.
anyone can help me ? thx very much.
convertToMeters 0.1;
vertices
(0 0 0)
(0.4 0 0)
(0.5 0 0)
(1 0 0)
(0 1 0)
(0.4 1 0)
(0.5 1 0)
(1 1 0)
(0.4 2 0)
(0.5 2 0)
(0 0 0.1)
(0.4 0 0.1)
(0.5 0 0.1)
(1 0 0.1)
(0 1 0.1)
(0.4 1 0.1)
(0.5 1 0.1)
(1 1 0.1)
(0.4 2 0.1)
(0.5 2 0.1)
blocks
hex (0 1 5 4 10 11 15 14) (10 20 1) simpleGrading (1 1 1)// why I can not revise this code in red?
hex (1 2 6 5 11 12 16 15) (5 20 1) simpleGrading (1 1 1)
hex (2 3 7 6 12 13 17 16) (10 20 1)simpleGrading (1 1 1)
hex (5 6 9 8 15 16 19 18) (5 20 1)simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(8 18 19 9)
leftWall
type wall;
faces
(0 4 14 10)
rightWall
type wall;
faces
(3 13 17 7)
lowerWall
type wall;
faces
(0 10 11 1)
(1 11 12 2)
(2 12 13 3)
upWall
type wall;
faces
(4 14 15 5)
(6 16 17 7)
upleftWall
type wall;
faces
(5 15 18 8)
uprightWall
type wall;
faces
(6 16 19 9)
mergePatchPairs
sharonyue is offline   Reply With Quote
Old   September 30, 2012, 03:10
Alberto Passalacqua
The part in red is the number of nodes in each direction for the corresponding block. Since blocks are connected, the numbers have to be consistent. Most likely you are trying to specify an inconsistent discretization (different number of nodes on the same edge shared by two blocks, o opposite edges, for example).
Best,
Alberto Passalacqua
Old   September 30, 2012, 20:34
Dongyue Li
Best,
woo!!!!!!!!!!!!!!!!!!it works!!! thx very much!!
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow Aliiiii OpenFOAM Running, Solving & CFD 1 February 27, 2019 12:26
Simple melting problem wawa FLUENT 0 January 28, 2011 12:19
Floating point error in BlockMesh for really simple mesh CoenW OpenFOAM Bugs 3 July 22, 2009 06:33
Simple Meshing Problem with Gambit Mario FLUENT 4 April 18, 2003 09:52
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 06:19
