June 30, 2018, 13:13 |
compound volume
I am trying to generate structured mesh using Gmsh, the problem i find is, when i run simulation in openfoam using .msh file , openfoam takes each of the volume as seperately, i want to combine all volumes together. Can anyone help please.
I am posting my .geo code lines file here Point(2) = {0.0125, 0, 0, 1.0}; Point(3) = {3, 0, 0, 1.0}; Point(4) = {3, 0.025, 0, 1.0}; Point(5) = {0.0125, 0.025, 0, 1.0}; Point(6) = {0.0125, 0.0125, 0, 1.0}; Point(7) = {-0.0125, 0.0125, 0, 1.0}; Point(8) = {-0.0125, 0.025, 0, 1.0}; Point(9) = {-3, 0.025, 0, 1.0}; Point(10) = {-3, 0, 0, 1.0}; Point(12) = {-0.0125, 0, 0, 1.0}; Point(13) = {3, 0.0125, 0, 1.0}; Point(14) = {-3, 0.0125, 0, 1.0}; Line(1) = {12, 2}; Line(2) = {7, 6}; Line(3) = {2, 3}; Line(4) = {5, 4}; Line(5) = {3, 13}; Line(7) = {13, 4}; Line(8) = {2, 6}; Line(9) = {6, 5}; Line(10) = {12, 7}; Line(11) = {7, 8}; Line(12) = {10, 14}; Line(13) = {14, 9}; Line(14) = {6, 13}; Line(16) = {12, 10}; Line(17) = {7, 14}; Line(18) = {8, 9}; Line Loop(19) = {2, -8, -1, 10}; Plane Surface(20) = {19}; Line Loop(21) = {4, -7, -14, 9}; Plane Surface(22) = {21}; Line Loop(23) = {14, -5, -3, 8}; Plane Surface(24) = {23}; Line Loop(25) = {18, -13, -17, 11}; Plane Surface(26) = {25}; Line Loop(27) = {17, -12, -16, 10}; Plane Surface(28) = {27}; Transfinite Line {1, 2} = 5 Using Progression 1; Transfinite Line {3, 14, 4} = 25 Using Progression 1; Transfinite Line {16, 17, 18} = 25 Using Progression 1; Transfinite Line {8, 10, 5, 12} = 5 Using Progression 1/1; Transfinite Line {13, 11, 9, 7} = 5 Using Progression 1/1; Transfinite Surface {22}; Transfinite Surface {24}; Transfinite Surface {20}; Transfinite Surface {28}; Transfinite Surface {26}; Recombine Surface {20, 22, 24, 26, 28}; Extrude {{1, 0, 0}, {0, 0, 0}, Pi} { Surface{22, 24, 20, 28, 26}; Layers{16}; Recombine; } Extrude {{1, 0, 0}, {0, 0, 0}, Pi/2} { Surface{101, 123, 84, 67, 50}; Layers{8}; Recombine; } Extrude {{1, 0, 0}, {0, 0, 0}, Pi/2} { Surface{162, 140, 179, 218, 196}; Layers{8}; Recombine; } Physical Surface("Inlet") = {231, 153, 114, 135, 96, 251}; Physical Surface("Outlet") = {280, 41, 209, 191, 62, 300}; Physical Surface("Wall") = {122, 239, 161, 49, 217, 288, 110, 37, 76, 149, 205, 171, 227, 276, 264}; Physical Volume("internal") = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15}; |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
[GAMBIT] Meshing T-pipe | maxpoint | ANSYS Meshing & Geometry | 19 | November 25, 2016 01:33 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[Commercial meshers] CuBit | t42 | OpenFOAM Meshing & Mesh Conversion | 6 | July 10, 2008 07:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
