[blockMesh] blockMesh error for 3d pipe
Like Tree1Likes
  • 1 Post By hxaxtma
Old   February 2, 2015, 18:41
Default blockMesh error for 3d pipe
nsreddy
nsreddysrsit is on a distinguished road
hi,
I am creating a blockMesh for pipe, here i am attaching geometry as well , I am getting error.
here is the Mesh file.
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.01;
vertices
(0 0 0) //0
(0.15 0.15 0)
(-0.15 0.15 0)
(-0.15 -0.15 0)
(0.15 -0.15 0)
(0.3 0.3 0)//5
(-0.3 0.3 0)
(-0.3 -0.3 0)
(0.3 -0.3 0)
(0.3535 0.3535 0)//9
(-0.3535 0.3535 0)
(-0.3535 -0.3535 0)
(0.3535 -0.3535 0)
(0.15 0.15 30)//13
(-0.15 0.15 30)
(-0.15 -0.15 30)
(0.15 -0.15 30)
(0.3 0.3 30) //17
(-0.3 0.3 30)
(-0.3 -0.3 30)
(0.3 -0.3 30)
(0.3535 0.3535 0) //21
(-0.3535 0.3535 0)
(-0.3535 -0.3535 0)
(0.3535 -0.3535 0)
(0 0 30) //25
blocks
hex (1 2 3 4 13 14 15 16) (10 10 150) simpleGrading (1 1 1)
hex (1 5 6 2 13 17 18 14) (10 10 150) simpleGrading (1 1 1)
hex (2 6 7 3 14 18 19 15) (10 10 150) simpleGrading (1 1 1)
hex (3 7 8 4 15 19 20 16) (10 10 150) simpleGrading (1 1 1)
hex (4 8 5 1 16 20 17 13) (10 10 150) simpleGrading (1 1 1)
hex (5 9 10 6 17 21 22 18) (10 10 150) simpleGrading (1 1 1)
hex (6 10 11 7 18 22 23 19) (10 10 150) simpleGrading (1 1 1)
hex (7 11 12 8 19 23 24 20) (10 10 150) simpleGrading (1 1 1)
hex (12 9 5 8 24 21 17 20) (10 10 150) simpleGrading (1 1 1)
edges
arc 5 6 (0 0.42426 0)
arc 6 7 (-0.42426 0 0)
arc 7 8 (0 -0.42426 0)
arc 8 5 (0.42426 0 0)
arc 9 10 (0 0.5 0)
arc 10 11 (-0.5 0 0)
arc 11 12 ( 0 -0.5 0)
arc 12 9 (0.5 0 0)
arc 17 18 (0 0.42426 30)
arc 18 19 (-0.42426 0 30)
arc 19 20 (0 -0.42426 30)
arc 20 17 (0.42426 0 30)
arc 21 22 (0 0.5 30)
arc 22 23 (-0.5 0 30)
arc 23 24 (0 -0.5 30)
arc 24 21 (0.5 0 30)
boundary
inlet
type inlet;
faces
(13 16 15 14)
(13 14 18 17)
(14 15 19 18)
(15 16 20 19)
(16 13 17 20)
(17 18 22 21)
(18 19 23 22)
(19 20 24 23)
(20 17 21 24)
outlet
type outlet;
faces
(1 5 6 2)
(2 6 7 3)
(3 7 8 4)
(4 8 5 1)
(1 2 3 4)
(5 9 10 6)
(6 10 11 7)
(7 11 12 8)
(8 12 9 5)
fixwdWalls
type fixedWalls;
faces
(21 22 10 9)
(22 23 11 10)
(23 24 12 11)
(24 21 9 12)
mergePatchPairs
Regards
File Type: png Screenshot from 2015-02-03 05:00:23.png (70.0 KB, 120 views)
nsreddysrsit is offline   Reply With Quote
Old   February 3, 2015, 04:38
hxaxtma is on a distinguished road
You had some mistakes in your blockMeshDict
- Forgotten curles )
and there are no patch types like inlet and outlet or fxdwalls.mist commonly used are patch, wall, emtpy, symmetryPlane, e.g.....
Here is the corrected Dictionary.
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 0.1;
vertices
    (0 0 0) //0
    (0.15 0.15 0)
    (-0.15 0.15 0)
    (-0.15 -0.15 0)
    (0.15 -0.15 0)
    (0.3 0.3 0)//5
    (-0.3 0.3 0)
    (-0.3 -0.3 0)
    (0.3 -0.3 0)
    (-0.3535 0.3535 0)
    (-0.3535 -0.3535 0)
    (0.3535 -0.3535 0)
    (0.15 0.15 30)//13
    (-0.15 0.15 30)
    (-0.15 -0.15 30)
    (0.15 -0.15 30)
    (0.3 0.3 30) //17
    (-0.3 0.3 30)
    (-0.3 -0.3 30)
    (0.3 -0.3 30)
    (-0.3535 0.3535 0)
    (-0.3535 -0.3535 0)
    (0.3535 -0.3535 0)
    (0 0 30) //25
blocks
edges
    arc 9 10 (0 0.5 0)
    arc 12 9 (0.5 0 0)
boundary
    inlet
        type patch;
        faces
        (13 16 15 14)
        (13 14 18 17)
        (14 15 19 18)
        (15 16 20 19)
        (16 13 17 20)
        (17 18 22 21)
        (18 19 23 22)
        (19 20 24 23)
        (20 17 21 24)
    fixedWalls
        type wall;
        faces
        (21 22 10 9)
        (22 23 11 10)
        (23 24 12 11)
        (24 21 9 12)
    outlet
        type patch;
        faces
        (1 5 6 2)
        (2 6 7 3)
        (3 7 8 4)
        (4 8 5 1)
        (1 2 3 4)
        (5 9 10 6)
        (6 10 11 7)
        (7 11 12 8)
        (8 12 9 5)
mergePatchPairs
hxaxtma is offline   Reply With Quote
Old   February 3, 2015, 04:43
And just a hint: I use following tools while creating blockMeshDicts
-pyFoamDisplayBlockMesh.py
-paraFoam -blocks
Old   February 3, 2015, 06:50
Default hi
nsreddy
thanks for the reply,
After checkMesh I am getting following error.
Checking geometry...
Overall domain bounding box (-1.43321 -1.43321 0) (1.43321 1.43321 3)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-8.33742e-18 -1.47677e-16 -3.01599e-18) OK.
***High aspect ratio cells found, Max aspect ratio: 4896.76, number of cells 2704
<<Writing 2704 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 7.56604e-07. Maximum face area = 0.247873. Face area magnitudes OK.
Min volume = 2.46125e-08. Max volume = 1.77893e-05. Total volume = 0.2571. Cell volumes OK.
Mesh non-orthogonality Max: 180 average: 52.447
*Number of severely non-orthogonal (> 70 degrees) faces: 147240.
***Number of non-orthogonality errors: 5716.
<<Writing 152956 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 11432 faces are incorrectly oriented.
<<Writing 5716 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 9.38368, 36 highly skew faces detected which may impair the quality of the results
<<Writing 36 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 4 mesh checks.
Best Regards
Old   February 3, 2015, 13:49
Well you defined your geometry wrong...
this is what I got, looks like a space fighter from star wars.
I am missing time at the moment. Maybe during the week I can fix it.
Old   February 3, 2015, 13:53
Quick Google search,
example Code for "good" pipe mesh. Just adapt it to your data:
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
//internal square
    (0 -1 -1) //0
    (1 -1 -1) //1
    (1 -1  1) //2
    (0 -1  1) //3
    (0  1 -1) //4
    (1  1 -1) //5
    (1  1  1) //6
    (0  1  1) //7
//Going clockwise with sections
//North section
    (0  2  2) //8
    (0 -2  2) //9
    (1  2  2) //10
    (1 -2  2) //11
//East section
    (0  2 -2) //12
    (1  2 -2) //13
//South section
    (0 -2 -2) //14
    (1 -2 -2) //15
edges
//North section
   arc  8  9 (0  0     2.82)
   arc 10 11 (1  0     2.82)
//East section
   arc  8 12 (0  2.82  0)
   arc 10 13 (1  2.82  0)
//South section
   arc 12 14 (0  0 -2.82 )
   arc 13 15 (1  0 -2.82 )
//West section
   arc 14  9 (0  -2.82 0)
   arc 15 11 (1  -2.82 0)
blocks
//Centre
    hex (4 5 6 7 0 1 2 3) (32 48 48) simpleGrading (1 1 1)
//East section
    hex (8 10 11 9 7 6 2 3) (32 48 92) simpleGrading (1 1 0.25)
//East section
    hex (12 13 10 8 4 5 6 7) (32 48 92) simpleGrading (1 1 0.25)
//South section
    hex (14 15 13 12 0 1 5 4) (32 48 92) simpleGrading (1 1 0.25)
//West section
    hex (9 11 15 14 3 2 1 0) (32 48 92) simpleGrading (1 1 0.25)
patches
    wall pipeWall
        (9 11 10 8)
        (8 10 13 12)
        (12 14 15 13)
        (14 9 11 15)
    cyclic cNorth
        (9  3 7  8)
        (11 2 6 10)
    cyclic cEast
        (7  4 12  8)
        (6  5 13 10)
    cyclic cSouth
        (0 14 12 4)
        (1 5 13 15)
    cyclic cWest
        (0 14 9 3)
        (1 15 11 2)
    cyclic cCentre
        (0 4 7 3)
        (1 2 6 5)
mergePatchPairs
alethea24 likes this.
Old   February 5, 2015, 10:12
Default hi
nsreddy
thank you,
i will try
[blockMesh] Quarter pipe with blockMesh kaber OpenFOAM Meshing & Mesh Conversion 1 January 10, 2018 21:51
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 00:19
[blockMesh] blockMesh pipe problem xiyuqiu OpenFOAM Meshing & Mesh Conversion 6 July 22, 2014 23:50
Double Walled Pipe Boundary dahvqaz FLUENT 2 December 5, 2012 10:14
[GAMBIT] Meshing a pipe vedravi ANSYS Meshing & Geometry 1 March 25, 2010 13:19
