April 13, 2016, 09:26 |
Error - Block Mesh
Maral Mohajer
Rep Power: 10 |
Hi everyone ,
I'm facing some problems creating mesh via blockMesh. my vertices , blocks and arcs are mentioned below. Could you please help me with ? without running blockMesh, how can I see my vertex and arcs? parafoam -block just is available after crerating blockMesh , do we have sth if there are even errors in blockMesh ? I'm attaching necessary files from error as well as verex and blocks and edges . Regards Maral |
May 19, 2016, 11:17 |
Rep Power: 15 |
Without running blockMesh there is no mesh for OF to show you any details. You can try writing out your geometry to a VTK format (the legacy type) and then load that in Paraview: http://www.vtk.org/wp-content/upload...le-formats.pdf The error you encounter is the most common type of error in blockMesh. Basically the "face x has no ... " means that the vertices you have used to define the face DO NOT define a face. Most of the time this error is caused by an incorrect vertex numbering of a face. I have provided a solution in a few of the posts here, so perhaps you can take a look at that. Hope this helps. Cheers, Antimony |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
