[blockMesh] Flow in pipe with porous region - How to define cellzone?
Old   May 17, 2016, 12:11
Default Flow in pipe with porous region - How to define cellzone?
g7fernandes is on a distinguished road
I am new OpenFoam user I want to do something very simple:
There is a 2d pipe and in the middle there is a porous wall.
I used blockmesh with 3 blocks with equal sizes and the block in the middle should be the porous media.
How do I indicate to OpenFoam that there is a porous region?
I read about CellZone and Setset, but I can't find exactly what must I write and were
I'm using porousSimpleFoam and blockMesh.
If someone has the codes for such simulation to share, I and the Internet will be very thankfull to you and many people in the future will love you.
The "tutorials" that come with openFoam are very unclear.
g7fernandes is offline   Reply With Quote
Old   May 17, 2016, 20:52
Antimony is on a distinguished road
Look at the topoSet utility: https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict
You can define your cellZone using that. There are multiple options: boxToCell, cylinderToCell etc that you can use to get your cellZone.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   May 18, 2016, 08:22
Thank you for your reply!
I created the file topoSetDict and I put it in /system
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
    // Load initial cellSet
        name    porosity;
        type    cellSet;
        action  new;
        source boxToCell;
        sourceInfo
            box (20 0 0) (40 20 1);
With this mesh
|  \\    /   O peration     | Version:  3.0.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices   // points in the flow space
    (0 0 0)  // 0
    (20 0 0)  // 1
    (20 20 0)  // 2
    (0 20 0)  // 3
    (0 0 1)  // 4
    (20 0 1)  // 5
    (20 20 1)  // 6
    (0 20 1)  // 7
    (40 0 0)  // 8
    (40 20 0)  // 9
    (40 0 1)  // 10
    (40 20 1)  // 11
    (60 0 0)  // 12
    (60 20 0)  // 13
    (60 0 1)  // 14
    (60 20 1)  // 15
blocks
    hex (0 1 2 3 4 5 6 7) (30 30 1)
// the order of the numbers in hex ( ) defines the vertices of the tetrahedron (region of flow)
// Important: The first two digits in hex ( ) defines x-direction, the first and the third
//            defines the Y, and the first and the fifth defines the Z
    simpleGrading (1 1 1)  //defines the grid
    hex (1 8 9 2 5 10 11 6) (30 30 1)
    hex (8 12 13 9 10 14 15 11) (30 30 1)
edges  // used in the case of drawing curves
boundary   // names the faces
    inlet
        type patch;
        faces
            (0 3 4 7)  //face determinated by this vertices is the inlet
    outlet
        type patch;
        faces
            (12 13 15 14)
    walls
        type wall;
        faces
            (0 1 5 4)
            (2 3 6 7)
            (8 12 14 10)
            (9 13 11 15)
    porosityWall
        type wall;
        faces
            (1 8 5 10) //
            (2 9 6 11) //
    frontAndBack
        type empty;
        faces
            (0 3 2 1)
            (4 5 6 7)
            (5 10 11 6)
            (1 8 9 2)
            (8 12 13 9)
            (10 14 15 11)
mergePatchPairs
but I get this error when I run porousSimpleFoam
Build  : 3.0.1-119cac7e8750
Exec   : porousSimpleFoam
Date   : May 18 2016
Time   : 14:12:17
Host   : "ubuntu-mate-1510"
PID    : 29189
Case   : /home/ofuser/OpenFOAM/ofuser-3.0.1/run/sq_porous
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 100 steps.
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
Creating porosity model list from porosityProperties
Porosity region porosity1:
    selecting model: DarcyForchheimer
    creating porous zone: porosity
--> FOAM FATAL ERROR:
cannot find porous cellZone porosity
    From function Foam::porosityModel::porosityModel(const Foam::word&, const Foam::word&, const Foam::fvMesh&, const Foam::dictionary&, const Foam::word&)
    in file cfdTools/general/porosityModel/porosityModel/porosityModel.C at line 121.
FOAM exiting
What I'm doing wrong?
Old   May 18, 2016, 08:56
At the moment it is still a cellSet, not a cellZone. You will need to do one more step in your topoSet to get that. Look for setToCellZone to do the conversion.
Hope this helps.
Cheers,
Antimony
cellzones, pipe flow, porosity;niyama, porous interface
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
