[blockMesh] blockMesh problem with wedge blocks
Old   September 14, 2016, 05:49
Default blockMesh problem with wedge blocks
gned
gned is on a distinguished road
dear Foamers,
I found a possible problem with blockMesh on OF 2.3 .
One block of my larger mesh is wedge shaped, even if any of its boundaries will be of the "type wedge" (but just of the type patch) because this larger mesh is not an axisymmetric geometry. Two edges are circular arcs. Here attached you find a pic of just this only problematic block for simplification. As you can see face (0 4 5 3) in on the coordinate plane zy.
The blockMeshDict seems to me OK. But when I use it with OF2.3 and a simpleGrading with a certain number of cells (for ex. (6 64 9)), the blockMesh seems still to work, but no more the checkMesh and in paraFoam indeed I have the error in red in the second pic in wireframe. On the contrary, with for instance another n° of cells (for ex. (4 23 9)) or using OF2.1 the problem disappears, with all the checkMeshes succeeding. I attached the case.
Need help for understanding, because this causes me bigger problems later to conform this block with the larger mesh.
wedgeblockForum.tar.gz
gned is offline   Reply With Quote
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[blockMesh] mesh grading problem with multiple blocks aljaz OpenFOAM Meshing & Mesh Conversion 0 December 21, 2010 02:33
blockMesh problem shangzung OpenFOAM 5 December 9, 2009 08:18
