[Commercial meshers] fluent mesh conversion to foam
Old   November 14, 2016, 06:57
Default fluent mesh conversion to foam
sangram
sangram is on a distinguished road
Hello Everyone,
I am trying to import mesh (.msh file) from fluent to OpenFoam. When I enter command "fluentMeshToFoam", I am getting following error. I am using chtMultiRegionSimpleFaom solver. Need help..
Thanks in advance.
--> FOAM FATAL IO ERROR:
wrong token type - expected int, found on line 0 the punctuation token ')'
file: IStringStream.sourceFile at line 0.
From function operator>>(Istream&, int&)
in file primitives/ints/int/intIO.C at line 69.
FOAM exiting
sangram is offline   Reply With Quote
Old   November 14, 2016, 07:14
sangram
I got the solution in one of my older posts. I did not get it As I was using OpenFoam after long time.
Here is the solution:
Please follow this way: workbench Mesh: tool - option - meshing- export - ansys fluent - format of input file - ascii
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[Commercial meshers] Thin Walls Conversion from Fluent Mesh Isaac OpenFOAM Meshing & Mesh Conversion 1 March 4, 2016 12:08
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
