[blockMesh] Meshing a wedge
Old   March 23, 2017, 09:46
Default Meshing a wedge
veronica2015 is on a distinguished road
I am creating a mesh of a simple wedge composed by two blocks. The case with another geometry runs well, but when I put my data I am getting the following error.
Create time
Creating block mesh from
"/home/veronica/Escritorio/new_simulations/KandM_H-D-10_2/constant/polyMesh/blockMeshDict"
Creating curved edges
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::arcEdge::calcAngle() in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libblockMesh.so"
#4 Foam::arcEdge::arcEdge(Foam::Field<Foam::Vector<do uble> > const&, Foam::Istream&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libblockMesh.so"
#5 Foam::curvedEdge::addIstreamConstructorToTable<Foa m::arcEdge>::New(Foam::Field<Foam::Vector<double> > const&, Foam::Istream&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libblockMesh.so"
#6 Foam::curvedEdge::New(Foam::Field<Foam::Vector<dou ble> > const&, Foam::Istream&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libblockMesh.so"
#7 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libblockMesh.so"
#8 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) in "/opt/openfoam230/platforms/linuxGccDPOpt/lib/libblockMesh.so"
in "/opt/openfoam230/platforms/linuxGccDPOpt/bin/blockMesh"
#10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11
Excepción de coma flotante (`core' generado)
The blockMeshDict is:
convertToMeters 1;
vertices
(0 0 0) //0
(3.174516432e-3 0 5.541139044e-5) //1
(0.1904709859 0 3.324683426e-3) //2
(0 0.635 0) //3
(3.174516432e-3 0.635 5.541139044e-5) //4
(0.1904709859 0.635 3.324683426e-3) //5
(3.174516432e-3 0 -5.541139044e-5) //6
(0.1904709859 0 -3.324683426e-3) //7
(3.174516432e-3 0.635 -5.541139044e-5) //8
(0.1904709859 0.635 -3.324683426e-3) //9
blocks
hex (1 4 3 0 6 8 3 0) (34 112 1) simpleGrading (1 2.05671982525299e-4 1) //block 1
hex (2 5 4 1 7 9 8 6) (64 112 1) simpleGrading (150.0842276 2.05671982525299e-4 1) //block 2
edges
arc 2 7 (0.1905 0 0)
arc 5 12 (0.1905 0.635 0)
boundary
inlet
type patch;
faces
(3 4 8 3)
outlet
type patch;
faces
(2 7 9 5)
upperWall
type wall;
faces
(4 5 9 8)
lowerWall
type wall;
faces
(0 6 1 0)
(1 6 7 2)
wedge1
type wedge;
faces
(0 1 4 3)
(1 2 5 4)
wedge2
type wedge;
faces
(0 3 8 6)
(6 8 9 7)
mergePatchPairs
Any help please?
Thanks so much
veronica2015 is offline   Reply With Quote
Old   March 23, 2017, 12:11
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
One mistake is for sure, that you used nodes twice in hex element 1:
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 23, 2017, 12:25
I have done that in other simulations and it has not been a problem. It corresponds to the first block that is a triangle.
Old   March 23, 2017, 13:06
piu58's Avatar
Uwe Pilz
If you need a triangle take one: OF offers triangles.
If you mesh this way cell faces have zero area.
Uwe Pilz
Old   March 23, 2017, 17:04
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
What shape are you tying to apply wedge on? I could make that in gmsh quickly. Just provide your dimensions and it should be easy.
Cheers,
tareqkh is offline   Reply With Quote
blockmesh
Wedge and morpher Henry Arrigo STAR-CCM+ 5 July 6, 2012 18:34
axisymmetric wedge case problem comedy_tigers88 OpenFOAM Running, Solving & CFD 0 June 16, 2012 04:45
[blockMesh] Problems meshing wedge type blocks Alan OpenFOAM Meshing & Mesh Conversion 0 July 27, 2009 20:05
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
