[blockMesh] BlockMesh checks
Old   April 15, 2007, 00:21
Default BlockMesh checks
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
If I know that my blockMeshDict is perfect; let's say I tested it using lesser number of nodes in all three directions and everything was fine, then is there anyway to skip all checks when running blockMesh?
The reason I ask is because I'm trying to do a mesh refinement study and the resulting mesh will be around 56 million cells, I would like to cut down on any time involved in checking.
If this is possible, can someone tell me which lines to comment in the source?
msrinath80 is offline   Reply With Quote
Old   April 16, 2007, 06:47
Default There is very minimal checking
Eugene de Villiers
eugene is on a distinguished road
There is very minimal checking during blockMesh and all in the polyMesh constructors. So unfortunately, there is no easy way of reducing the blockMesh overhead (although it certainly is possible).
eugene is offline   Reply With Quote
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
