[blockMesh] Mesh skewness warning how to get rid
Old   December 7, 2005, 17:19
Default Mesh skewness warning how to get rid
Charles Ju
ploceus is on a distinguished road
Hi.
I created mesh input file, and after running blockMesh, it produces points, faces and cells file. I can also use paraView to look at grids. They look fine but I have the following message below that can't get rid of. What does skewness mean? And how do I get rid of them?
Thanks.
Creating merge patch pairs
Adding point and face zones
Adding topology modifiers
--> FOAM Warning :
From function primitiveMesh::checkFaceSkewness(const bool report, labelHashSet* setPtr) const
in file meshes/primitiveMesh/primitiveMeshCheck.C at line 838
Large face skewness detected. Max skewness = 285.058 percent.
This may impair the quality of the result.
212 highly skew faces detected.
Failed 1 mesh geometry checks.
Failed some mesh checks.
Writing polyMesh
ploceus is offline   Reply With Quote
Old   December 7, 2005, 19:37
Default Mesh skewness means that the l
Hrvoje Jasak
hjasak will become famous soon enough
Mesh skewness means that the line connecting two cell centres misses the centre of the face between them, in your case by quite a lot.
This is only a warning and you can probably ignore it, but beware of the influence of the disretisation error to the solution accuracy in that region.
If you want to remove the error, you need to work on making a better mesh.
Enjoy,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   July 1, 2009, 05:01
Default comparing with Fluent
Jagmohan Meena
jmmeena is on a distinguished road
Respected Sir,
Can you please tell relation between mesh skewness reported by gambit and mesh skewness reported by OpenFOAM.
What is the upper limit of mesh skewness in OpenFOAM which can be related to 0.92 in gambit.
regards,
JM
jmmeena is offline   Reply With Quote
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Community Contributions 1 August 27, 2010 05:15
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
