[Gmsh] Problem with geometry.
Old   January 6, 2011, 04:56
Default Problem with geometry.
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
I built a simple geometry consisting of a circle inside a square. Then i extruded my geometry with 1 layer to have a 2D problem. Here my .geo file:
// Gmsh project created on Tue Jan 4 16:30:24 2011
lc = 0.0001;
d1 = 0.001;
r = 0.00014142;
c = 0.0005;
Point(1)={0, 0, 0, lc};
Point(2)={d1-0.0003, 0, 0, lc};
Point(3)={d1-0.0003, d1-0.0003, 0, lc};
Point(4)={0, d1-0.0003, 0, lc};
Point(5)={c+r-0.00015, c+r-0.00015, 0, lc};
Point(6)={c+r-0.00015, c-r-0.00015, 0, lc};
Point(7)={c-r-0.00015, c-r-0.00015, 0, lc};
Point(8)={c-r-0.00015, c+r-0.00015, 0, lc};
Point(9)={c-0.00015, c-0.00015, 0, lc};
Circle(1) = {5, 9, 8};
Circle(2) = {8, 9, 7};
Circle(3) = {7, 9, 6};
Circle(4) = {6, 9, 5};
Line(5) = {2, 3};
Line(6) = {3, 4};
Line(7) = {4, 1};
Line(8) = {1, 2};
Line Loop(9) = {1, 2, 3, 4};
Ruled Surface(10) = {9};
Line Loop(11) = {7, 8, 5, 6};
Plane Surface(12) = {11,9};
Extrude {0, 0, 0.00001} {
Surface{12};
Layers{1};
Recombine;
Surface{10};
Layers{1};
Recombine;
Physical Surface("top") = {37};
Physical Surface("bottom") = {29};
Physical Surface("left") = {25};
Physical Surface("right") = {33};
Physical Surface("front") = {54};
Physical Surface("back") = {12};
Physical Surface("obstacle") = {53, 49, 45, 41};
Physical Volume("internal") = {1};
OpenFoam impot the geometry without any problem and if i do CheckMesh everything is ok. I run the simulation (fluid enter on the top and displace another fluid) but something strange happens. The flow stops when it reaches exactly one of the points used to define the circle (point 5).
When I built the mesh I used the option "Mesh from curvature" in the mesh option in order to have these 4 (8 in 2D) points on the circle exactly on the edges of the prisms and not on the side but i got the same problem if I do not.
Maybe is a problem with boundary condition because i have to define 4 surfaces on the disc and not only one, but all 4 have the same patch "wall". Is there a way to define a single surface or otherwise any suggestion to solve the problem??
Thanks
Andrea
Andrea_85 is offline   Reply With Quote
Old   January 6, 2011, 08:34
Andrea Ferrari
I solved it!
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? Pol.P FLUENT 9 March 7, 2022 17:21
Problem with Scale in Geometry bejanyar CFX 4 October 14, 2015 07:53
[ANSYS Meshing] Problem with geometry paul115 ANSYS Meshing & Geometry 4 August 18, 2015 12:18
[Workbench] Problem with the geometry Memboro ANSYS Meshing & Geometry 0 July 26, 2013 02:18
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
