OpenFOAM and Adjoint solution
Old   March 6, 2014, 11:18
Default OpenFOAM and Adjoint solution
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi everyone,
I have read about the capability in OpenFOAM to run the Adjoint "version" of the Navier-Stokes equations for shape optimization.
Is there a way of just calculating the Adjoint solution so I can locate the more sensible regions in an afterbody (cartesian) wake in order to design wake stability measures?
Thanks!
aerospain is offline   Reply With Quote
Old   March 7, 2014, 05:43
Roland
sylvester is on a distinguished road
Probably best to start with the 'adjointShapeOptimizationFoam' solver (a simpleFoam derivative), while maintaining alpha = 0.
Beware though, adjoint simulations are notoriously unstable.
Good luck!
Sylvester
sylvester is offline   Reply With Quote
Old   March 7, 2014, 05:45
aerospain
Thank you Sylvester,
I'll give it a go during the weekend.
Where could I find info about keeping stability under control?
Thanks!
Old   March 7, 2014, 06:31
Roland
If I knew that, my (CFD) life would be so much better!
You could look up my old posts on adjoint, they might help you a bit. Since then I haven't worked the subject anymore, so I haven't made much additional progress.
regards,
Sylvester
adjoint Shape Optimization mechy OpenFOAM Running, Solving & CFD 11 June 19, 2017 09:05
Adjoint solver for flow problems jelmer OpenFOAM Running, Solving & CFD 11 March 12, 2017 06:52
adjoint method- uniformity Envolly OpenFOAM Programming & Development 8 July 9, 2013 01:29
Adjoint Methods in OpenFOAM treima OpenFOAM Programming & Development 4 May 24, 2012 05:57
OpenFOAM 1.7.1: Oscillating CFL number LarsPT OpenFOAM Running, Solving & CFD 4 September 18, 2010 03:55
