[Gmsh] Error when using gmshToFoam
Like Tree1Likes
  • 1 Post By GDTech
Old   March 23, 2014, 10:50
Default Error when using gmshToFoam
sur4j is on a distinguished road
I am trying to mesh a test component in GMSH but am having problems.
I meshed the component using the [Mesh] [3D] option and then saved as a .msh extension. When I tried to run this in OpenFOAM using gmshToFoam I got the following error:
Create time
Starting to read mesh format at line 2
Read format version 2.2  ascii 0
Starting to read physical names at line 5
Physical names:3
    Surface 1    frontAndBack
    Surface 2    base
    Surface 3    walls
Starting to read points at line 11
Vertices to be read:74
Vertices read:74
Starting to read cells at line 88
Cells to be read:122
Mapping region 1 to Foam patch 0
Mapping region 3 to Foam patch 1
Mapping region 2 to Foam patch 2
Cells:
    total:0
    hex  :0
    prism:0
    pyr  :0
    tet  :0
--> FOAM FATAL IO ERROR:
No cells read from file "gmshtest.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
file: gmshtest.msh at line 212.
    From function readCells(..)
    in file gmshToFoam.C at line 726.
FOAM exiting
Could someone please try this out and check it it works or please explain what I am doing wrong?
Thank you.
sur4j is offline   Reply With Quote
Old   April 3, 2014, 05:04
Laurent Fitschy
GDTech is on a distinguished road
I think you forgot to create a physical volume containing your 3D mesh as follow :
Physical Volume("fluid") = {1};
Regards,
Laurent.
bkassar likes this.
GDTech is offline   Reply With Quote
Old   April 15, 2014, 22:26
Lucas Mutti
lramutti is on a distinguished road
Hello Laurent,
I also have the same problem. In my case, I have imported a geometry created in CAD and I am trying to mesh it. How can define the fluid based on the provided parameters in gmsh?
Regards,
Lucas
lramutti is offline   Reply With Quote
Old   April 16, 2014, 08:06
Laurent Fitschy
Hi Lucas,
Check your elementary entities (menubar -> tools -> visibility) and add IDs of your volume(s) to the Physical Volume like this :
Physical Volume("fluid") = {1,2,3};
If you do not have any volume elementary entity, you have to define (at least) one volume entity with its bounding surfaces (geometry -> elementary entities -> add -> volume).
Regards,
Laurent.
Old   April 16, 2014, 12:41
Lucas Mutti
Hello Laurent,
Thanks for replying. I have tried to implement your suggestion however it seems that an elementary entity called surface 1 is already there for the analyzed STL. I tried to hit apply to see if it makes a difference and then refine but for some strange reason when I try to convert my .msh file into OpenFOAM I still get this message
No cells read from file "Harran_clean.msh"
file: Harran_clean.msh at line 13832697.
Then, I open my .geo file and it says the following:
Merge "Harran_clean.stl";
Surface Loop(2) = {1};
Would you mind if I forward to your e-mail my STL?
Regards,
Lucas
Old   April 17, 2014, 03:25
Laurent Fitschy
From my knowledge, gmsh is not able to build a 3D mesh from STL file. It handles STEP and IGES from CAD software.
Go to menubar -> tools -> statistics -> "mesh" tab and you will see you don't have any 3D mesh elements ...
Old   April 17, 2014, 03:53
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
in fact you've forgotten to add one line to your geo file:
Merge "your-stl-file.stl";
Volume(3) = {2};
and created msh file can be converted with gmshToFoam without errors (at least it was possible with my rather simple geometry).
alexeym is offline   Reply With Quote
[Gmsh] New version of gmshToFoam? stootoon OpenFOAM Meshing & Mesh Conversion 7 February 14, 2022 09:01
[Gmsh] gmshToFoam problem. nilashansen OpenFOAM Meshing & Mesh Conversion 11 June 5, 2016 10:45
[Gmsh] Cell to node connectivity after 'gmshToFoam' Jibran OpenFOAM Meshing & Mesh Conversion 1 June 8, 2015 09:09
[Gmsh] gmshTofoam pbm with cyclicAMI acahuzac OpenFOAM Meshing & Mesh Conversion 2 October 20, 2014 03:53
[Gmsh] gmshToFoam command mvinassa OpenFOAM Meshing & Mesh Conversion 1 April 25, 2014 07:36
