[Salome] Using Salome to repair non-watertight STL
Like Tree1Likes
  • 1 Post By chriss85
Old   December 19, 2014, 02:32
Default Using Salome to repair non-watertight STL
chriss85 will become famous soon enough
I've exported an stl file from a CAD program and snappyHexMesh has problems because there are seams between the different patches. Using Salome, I can use Repair->Sewing in the Geometry module to fix this. Unfortunately this results in the patches being combined so I lose the ability to specify boundary conditions later on. As the geometry is quite complex I don't want to manually piece the polygons together afterwards. Does anyone know of a method or tool that can do sewing while preserving the single patches?
Edit: Alternatively, is it sufficient to increase the precision until the seams become small enough?
Edit: Next idea, is it possible to use topoSet in combination with the old surfaces to split the patches again? I would guess that a few cells at the boundary might be wrong then, but maybe this could be a way?
lmw354 likes this.
chriss85 is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[Salome] Meshing a STL File in Salome Fool OpenFOAM Meshing & Mesh Conversion 0 November 28, 2018 09:39
[snappyHexMesh] Checkinf if SHM stl files are watertight fracasce OpenFOAM Meshing & Mesh Conversion 2 April 25, 2017 06:50
[CAD formats] Clean / Repair STL file with multiple regions on command line matthiasd OpenFOAM Meshing & Mesh Conversion 6 May 24, 2016 06:51
BioMedical STL Repair, Any Suggestions? EphemeralMemory ANSYS Meshing & Geometry 2 November 24, 2010 11:46
