[Salome] Is my mesh bad quority?
Old   August 6, 2015, 21:59
Default Is my mesh bad quority?
KeiJun is on a distinguished road
I calculated an air flow in a tank using "pitzDaily" tutorial of OpenFOAM.
The result seems to be something strange turbulent eddy (see the pictures on the URL below. The difference of the two results is the number of cells).
I calculated this using hexamesh of "Body Fitting" algorism of SALOME.
https://www.dropbox.com/s/z7aplky49tpy6lj/vessel1_47-u%26p%282%29.png?dl=0
https://www.dropbox.com/s/l2nucr7pj27fdpu/vessel1_50-u%26p%282%29.png?dl=0
Are these eddies valid?
If not, what are the reasons of these eddies generating? Mesh? Solver?
When using tetramesh of "Nitgen 1D-2D-3D" algorism, the below result was obtained. The eddy is not so strange.
https://www.dropbox.com/s/q7ps09otakyb4ur/vessel1_8-u%26p%283%29.png?dl=0
I'm looking forward to your comments.
KeiJun
KeiJun is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
