[blockMesh] Problem using paraFoam to view cavityGrade mesh file
Old   September 24, 2009, 01:53
Default Problem using paraFoam to view cavityGrade mesh file
anonymous
felik9 is on a distinguished road
I am having difficulty running paraFoam to view the mesh file for the cavityGrade case available in the openFoam tutorial. I get the following error message when I execute the command "paraFoam" within the case directory.
ERROR: In /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/applications/utilities/postProcessing/graphics/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx, line 189
vtkPV3FoamReader (0x8add298): could not find valid OpenFOAM mesh
ERROR: In /home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkExecutive.cxx, line 757
vtkCompositeDataPipeline (0x8a45e60): Algorithm vtkPV3FoamReader(0x8add298) returned failure for request: vtkInformation (0x8aeb258)
Debug: Off
Modified Time: 82767
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
Please note that I am using OpenFoam 1.6 for lunix 32 bit platform in Ubuntu 9.04.
If you have a solution, please let me know.
Thanks.
Felik9
felik9 is offline   Reply With Quote
Old   September 27, 2009, 15:31
Default Found Solution
anonymous
The problem was that I did not run blockMesh first, then paraFoam.
Thanks for viewing my post
cavitygrade, error, parafoam
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
