[Salome] How to hotwire Salome or OpenCascade?
Old   October 17, 2009, 01:56
Default How to hotwire Salome or OpenCascade?
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
I have installed Salome on Linux and OpenCascade on windows. As far as I know the installations were successful. Both programs demonstrate a gui on their website and apear to be promising. I have yet to find anything more than a geometry viewer with-in the installs. Thoughts?
The question that never seems to get answered in opensource documentation is; Where is the on switch?
Thanks guys!
ericnutsch is offline   Reply With Quote
Old   October 17, 2009, 02:33
Ahmed
Ahmed is on a distinguished road
Thanks guys!
What do you mean by the "on switch" "hotwire" etc...
On my Debian partition, I use the following script, save it to your /home/eric/ give it a name of your choice, chmod +x TheNameOfTheFile, then call using the dot command,i.e,
./TheNameOfTheFile
here it is
#! /bin/bash
cd salome_5.1.2
source env_products.sh
cd SALOME_5.1.2
cd bin
cd salome
./runSalome
if you visit the Salome forum, you will find answers to your questions and a set of tutorials........
Good Luck
Ahmed is offline   Reply With Quote
Old   October 17, 2009, 18:00
Eric Nutsch
Thanks for the reply Ahmed
I tried running the code you presented, but the SALOME_5.1.2 directory doesnt exist within salome_5.1.2. I deleted my old install, downloaded a fresh copy, and installed it. This time the install had an error in which libgfortran.so.1 failed to be installed. However, I was able to run the program once! Just before I clicked finish on the install it gave me the option to launch! Unfortuantly the libgfortran.so.1 issue prevented me from trying out anything other than the geometery.
I will have to fix that issue, but the current problem still stands; Where is the "exe"? I still dont know how to start it. I ran a locate for runSalome and found lots under kernal. I tried running every single one with no success. It shouldn't be an issue with my install because I a saw it run once.
Thoughts? Thanks again
Old   October 18, 2009, 06:26
Ahmed
the salome folder
Old   October 18, 2009, 06:28
Ahmed
The SALOME folder
Old   October 18, 2009, 06:31
Ahmed
The bin folder and finally the salome folder (and runSalome script)
Old   October 18, 2009, 16:59
Eric Nutsch
Ahmed, thanks for attaching print screens. I wish i could say that they helped. The directory does not exist.
Perhaps our installs are not the same. I am running Ubuntu 9.0.4. I downloaded the Debian 4.0 Etch 32bit version of Salome 5.1.2 from www.salome-platform.org
Do you think my install is to blame? Should I try installing a different version?
Thanks for your help
Old   October 18, 2009, 17:05
Eric Nutsch
Here is the output from a locate on runSalome:
eric@eric-desktop:~$ locate runSalome
/home/eric/salome_5.1.2/CALCULATOR_5.1.2/bin/salome/myrunSalome.py
/home/eric/salome_5.1.2/CALCULATOR_SRC_5.1.2/bin/myrunSalome.py
/home/eric/salome_5.1.2/DOCUMENTATION_SRC_5.1.2/KERNEL/doc/salome/gui/KERNEL/namespacerunSalome.html
/home/eric/salome_5.1.2/HELLO_5.1.2/bin/salome/myrunSalome.py
/home/eric/salome_5.1.2/HELLO_SRC_5.1.2/bin/myrunSalome.py
/home/eric/salome_5.1.2/KERNEL_5.1.2/bin/salome/runSalome
/home/eric/salome_5.1.2/KERNEL_5.1.2/bin/salome/runSalome.csh
/home/eric/salome_5.1.2/KERNEL_5.1.2/bin/salome/runSalome.ksh
/home/eric/salome_5.1.2/KERNEL_5.1.2/bin/salome/runSalome.py
/home/eric/salome_5.1.2/KERNEL_5.1.2/bin/salome/runSalome.pyc
/home/eric/salome_5.1.2/KERNEL_5.1.2/bin/salome/runSalome.pyo
/home/eric/salome_5.1.2/KERNEL_5.1.2/share/doc/salome/gui/KERNEL/namespacerunSalome.html
/home/eric/salome_5.1.2/KERNEL_SRC_5.1.2/bin/runSalome
/home/eric/salome_5.1.2/KERNEL_SRC_5.1.2/bin/runSalome.csh
/home/eric/salome_5.1.2/KERNEL_SRC_5.1.2/bin/runSalome.ksh
/home/eric/salome_5.1.2/KERNEL_SRC_5.1.2/bin/runSalome.py
/home/eric/salome_5.1.2/PYHELLO_5.1.2/bin/salome/myrunSalome.py
/home/eric/salome_5.1.2/PYHELLO_SRC_5.1.2/bin/myrunSalome.py
/home/eric/salome_5.1.2/YACS_5.1.2/bin/HXX2SALOME_Test/HXX2SALOME_GENERIC_CLASS_NAME_SRC/bin/runSalome.py
/home/eric/salome_5.1.2/YACS_SRC_5.1.2/src/wrappergen/bin/HXX2SALOME_GENERIC_CLASS_NAME_SRC/bin/runSalome.py
/home/eric/salome_5.1.2/YACS_SRC_5.1.2/src/wrappergen/src/HXX2SALOME_GENERIC_CLASS_NAME_SRC/bin/runSalome.py
I have attempted to run every single one with no luck.
Old   October 18, 2009, 19:06
Ahmed
No, it is the same file you downloaded,i.e.,InstallWizard_5.1.2_Debian_4.0,
I guess you did not check the box saying (Install all in the same directory), I do not think this is the reason, you see, you NEED to source the environmental variables before running the runSalome binary, so, do this, in the script I printed before, change the line that says cd SALOME_5.1.2 to
cd KERNEL_5.1.2
It should work
.........................................Open Source for ever.............................................. ....
Old   October 18, 2009, 21:15
Smile
Eric Nutsch
Your awesome Ahmed! Thanks!
Salome starts up just great.
For anyone else referenceing the forum; I used the code:
#! /bin/bash
cd salome_5.1.2
cd KERNEL_5.1.2
cd bin
cd salome
./runSalome
I put the code in a text file and saved.
Right clicked and set allow executing file as program under permissions.
Viola! One double click and Salome opens
Thanks Ahmed!
Now on to fix my installation...
how to run opencascade
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
Salome cgns format mesh to SU2 JPBLourenco SU2 19 November 18, 2019 02:11
[Gmsh] How to install OpenCASCADE for Gmsh 3.0.6 ? deepbandivadekar OpenFOAM Meshing & Mesh Conversion 1 June 13, 2018 05:31
[Salome] SALOME : How to define several CellZone utawalpa OpenFOAM Meshing & Mesh Conversion 0 March 23, 2018 13:19
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 08:59
