[Gmsh] Conversion Error
Old   February 20, 2010, 12:17
Default Conversion Error
Emanuele
nuovodna is on a distinguished road
Hi, i have a problem in conversion process of attached msh file made by gmsh 2.4.2
|  \\    /   O peration     | Version:  1.6                                   |
Build  : 1.6-53b7f692aa41
Exec   : gmshToFoam parziale.msh
Date   : Feb 20 2010
Time   : 18:13:36
Host   : ububox
PID    : 12595
Case   : /home/simulation/OpenFOAM/simulation-1.6/tutorials/incompressible/simpleFoam/airFoil3D
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Found $MeshFormat tag; assuming version 2 file format.
Starting to read physical names at line 5
Physical names:3
wrong token type - expected string found on line 0 the label 1
file: IStringStream.sourceFile at line 0.
    From function operator>>(Istream&, string&)
    in file primitives/strings/string/stringIO.C at line 57.
FOAM exiting
I tried to launch gmshToFoam and filename without extension .msh and it gave this error
Create time
#0  Foam::error::printStack(Foam::Ostream&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2  Uninterpreted:
#3  main in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/gmshToFoam"
#4  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#5  _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Segmentation fault
Partially solved: removing gmsh label it gives me other errors
Starting to read points at line 5
Vertices to be read:794
Vertices read:794
Starting to read cells at line 802
Cells to be read:1544
Mapping region 41 to Foam patch 0
Mapping region 35 to Foam patch 1
Mapping region 38 to Foam patch 2
Mapping region 36 to Foam patch 3
Mapping region 37 to Foam patch 4
Mapping region 39 to Foam patch 5
Mapping region 40 to Foam patch 6
Cells:
    total:0
    hex  :0
    prism:0
    pyr  :0
    tet  :0
No cells read from file "parziale.msh"
Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)?
Perhaps you have not exported the 3D elements?
    From function readCells(..)
    in file gmshToFoam.C at line 662.
FOAM exiting
Opening the .msh file with gmsh there aren't any 3d cell. How can i export the whole 3d cell to .msh file?
nuovodna is offline   Reply With Quote
Old   February 20, 2010, 20:09
Emanuele
I add Physical Volume and now it gives me other errors :
Vertices to be read:5236
Vertices read:5236
Starting to read cells at line 5244
Cells to be read:19212
Mapping region 56 to Foam patch 0
Mapping region 55 to Foam cellZone 0
Cells:
    total:14409
    hex  :0
    prism:0
    pyr  :0
    tet  :14409
CellZones:
Zone	Size
    0	14409
Skipping tag  at line 24459
Patch 0 gets name patch0
--> FOAM Warning :
    From function polyMesh::polyMesh(... construct from shapes...)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 577
    Found 10472 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
FaceZones:
Zone	Size
Writing zone 0 to cellZone cellZone_0 and cellSet
End
Old   April 21, 2010, 10:59
Default Issues with mesh tolerances after using gmshToFoam
Anonymous
madad2005 is on a distinguished road
Deleted. Should have been a new thread.
Does gmshToFoam still produce a mesh at the end? Have you tried running checkMesh to see what errors it picks up?
madad2005 is offline   Reply With Quote
Old   June 7, 2010, 09:40
Default No importing of physical surfaces and run doesn't start
Emanuele
I change my case. I m trying to simulate a dam break case. I have this .geo file
cl1 = 0.1;
Point(1) = {0, 0, 0, cl1};
Point(2) = {3.2196, 0, 0, cl1};
Point(3) = {3.2196, 1.8, 0, cl1};
Point(4) = {3.2196, 1.8, 0.1, cl1};
Point(5) = {3.2196, 0, 0.1, cl1};
Point(6) = {0, 0, 0.1, cl1};
Point(7) = {0, 1.8, 0.1, cl1};
Point(8) = {0, 1.8, 0, cl1};
Point(9) = {1.2, 0, 0, cl1};
Point(10) = {1.2, 0, 0.1, cl1};
Point(11) = {1.2, 0.6, 0.1, cl1};
Point(12) = {1.2, 0.6, 0, cl1};
Point(13) = {0, 0.6, 0, cl1};
Point(14) = {0, 0.6, 0.1, cl1};
Line(1) = {7, 14};
Line(2) = {14, 6};
Line(3) = {6, 1};
Line(4) = {1, 13};
Line(5) = {13, 8};
Line(6) = {8, 7};
Line(7) = {14, 13};
Line(8) = {7, 4};
Line(9) = {3, 8};
Line(10) = {3, 4};
Line(11) = {5, 4};
Line(12) = {3, 2};
Line(13) = {2, 5};
Line(14) = {10, 5};
Line(15) = {2, 9};
Line(16) = {9, 12};
Line(17) = {12, 11};
Line(18) = {10, 9};
Line(19) = {11, 14};
Line(20) = {13, 12};
Line(21) = {11, 10};
Line(22) = {10, 6};
Line(23) = {1, 9};
Line Loop(25) = {8, -10, 9, 6};
Plane Surface(25) = {25};
Line Loop(27) = {1, 7, 5, 6};
Plane Surface(27) = {27};
Line Loop(31) = {2, 3, 4, -7};
Plane Surface(31) = {31};
Line Loop(33) = {13, 11, -10, 12};
Plane Surface(33) = {33};
Line Loop(40) = {20, 17, 19, 7};
Plane Surface(40) = {40};
Line Loop(42) = {16, 17, 21, 18};
Plane Surface(42) = {42};
Line Loop(44) = {23, -18, 22, 3};
Plane Surface(44) = {44};
Line Loop(46) = {15, -18, 14, -13};
Plane Surface(46) = {46};
Line Loop(48) = {16, -20, -4, 23};
Plane Surface(48) = {48};
Line Loop(50) = {22, -2, -19, 21};
Plane Surface(50) = {50};
Line Loop(54) = {5, -9, 12, 15, 16, -20};
Plane Surface(54) = {54};
Line Loop(56) = {8, -11, -14, -21, 19, -1};
Plane Surface(56) = {56};
Surface Loop(52) = {48, 42, 40, 50, 31, 44};
Volume(52) = {52};
Surface Loop(58) = {56, 25, 33, 46, 54, 27, 40, 42};
Volume(58) = {58};
Physical Surface(60) = {25};
Physical Surface(61) = {27,31};
Physical Surface(62) = {44, 46};
Physical Surface(63) = {33};
Physical Volume(59) = {52, 58};
When i try to import .msh file in OpenFOAM i got this warning
Vertices to be read:1586
Vertices read:1586
Starting to read cells at line 1594
Cells to be read:5390
Mapping region 0 to Foam patch 0
Mapping region 0 to Foam cellZone 0
Cells:
    total:5006
    hex  :0
    prism:0
    pyr  :0
    tet  :5006
CellZones:
Zone    Size
    0    5006
Skipping tag  at line 6987
--> FOAM Warning :
    Found 2946 undefined faces in mesh; adding to default patch.
FaceZones:
Zone    Size
End
and the physical surfaces are not imported as i defined them in .geo file
checkMesh output :
Mesh stats
    faces:            11485
    internal faces:   8539
    cells:            5006
    boundary patches: 2
    point zones:      0
    face zones:       0
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     0
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    5006
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    patch0              384      332      ok (non-closed singly connected)
    defaultFaces        2562     1423     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 0 0) (3.2196 1.8 0.1)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Boundary openness (-1.58397e-18 -9.84818e-18 -5.54391e-17) OK.
    Max cell openness = 4.99737e-16 OK.
    Max aspect ratio = 518.051 OK.
    Minumum face area = 7.19968e-05. Maximum face area = 0.00992881.  Face area magnitudes OK.
    Min volume = 1.43759e-07. Max volume = 0.000323876.  Total volume = 0.579528.  Cell volumes OK.
    Mesh non-orthogonality Max: 88.7287 average: 25.4321
   *Number of severely non-orthogonal faces: 49.
    Non-orthogonality check OK.
  <<Writing 49 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 1.22583 OK.
Mesh OK.
When i start the interFoam run i have this error:
--> FOAM FATAL IO ERROR:
    patch type 'patch' not constraint type 'empty'
    for patch defaultFaces of field p in file "/home/emanuelet/Case_GMSH/0/p"
Changing the boundary file and switching defaultFaces from patch to empty i got this new error:
--> FOAM FATAL ERROR:
This mesh contains patches of type empty but is not 1D or 2D
    by virtue of the fact that the number of faces of this
    empty patch is not divisible by the number of cells.
    From function emptyFvPatchField<Type>::updateCoeffs()
    in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 151.
FOAM exiting
How can i fix it??
Thanks in advance
Emanuele
EDIT: Using gmsh 2.5.0 from svn it doesn't export patch. Solved using gmsh 2.2.3. Error on empty patch still appear...
Old   June 7, 2010, 10:52
Default Problems solved
Emanuele
Solved using extrude gmsh function instead of defining two different surface. It's my new workin .geo file:
Point (1) = {0, 0, 0, 0.1};
Point (2) = {3.2196, 0, 0, 0.1};
Point (3) = {3.2196, 1.8, 0, 0.1};
Point (8) = {0, 1.8, 0, 0.1};
Point (9) = {1.2, 0, 0, 0.1};
Point (12) = {1.2, 0.6, 0, 0.1};
Point (13) = {0, 0.6, 0, 0.1};
Point (14) = {0, 1.8, 0.1, 0.1};
Point (15) = {3.2196, 1.8, 0.1, 0.1};
Point (19) = {3.2196, 0, 0.1, 0.1};
Point (23) = {1.2, 0, 0.1, 0.1};
Point (27) = {1.2, 0.6, 0.1, 0.1};
Point (31) = {0, 0.6, 0.1, 0.1};
Point (37) = {0, 0, 0.1, 0.1};
Line (1) = {8, 3};
Line (2) = {3, 2};
Line (3) = {2, 9};
Line (4) = {9, 12};
Line (5) = {12, 13};
Line (6) = {13, 1};
Line (7) = {1, 9};
Line (8) = {13, 8};
Line (14) = {14, 15};
Line (15) = {15, 19};
Line (16) = {19, 23};
Line (17) = {23, 27};
Line (18) = {27, 31};
Line (19) = {31, 14};
Line (21) = {8, 14};
Line (22) = {3, 15};
Line (26) = {2, 19};
Line (30) = {9, 23};
Line (34) = {12, 27};
Line (38) = {13, 31};
Line (47) = {31, 37};
Line (48) = {37, 23};
Line (56) = {1, 37};
Line Loop (10) = {1, 2, 3, 4, 5, 8};
Plane Surface (10) = {10};
Line Loop (12) = {5, 6, 7, 4};
Plane Surface (12) = {12};
Line Loop (23) = {1, 22, -14, -21};
Ruled Surface (23) = {23};
Line Loop (27) = {2, 26, -15, -22};
Ruled Surface (27) = {27};
Line Loop (31) = {3, 30, -16, -26};
Ruled Surface (31) = {31};
Line Loop (35) = {4, 34, -17, -30};
Ruled Surface (35) = {35};
Line Loop (39) = {5, 38, -18, -34};
Ruled Surface (39) = {39};
Line Loop (43) = {8, 21, -19, -38};
Ruled Surface (43) = {43};
Line Loop (44) = {14, 15, 16, 17, 18, 19};
Plane Surface (44) = {44};
Line Loop (57) = {6, 56, -47, -38};
Ruled Surface (57) = {57};
Line Loop (61) = {7, 30, -48, -56};
Ruled Surface (61) = {61};
Line Loop (66) = {18, 47, 48, 17};
Plane Surface (66) = {66};
Surface Loop (1) = {10, 44, 23, 27, 31, 35, 39, 43};
Volume (1) = {1};
Surface Loop (2) = {12, 66, 39, 57, 61, 35};
Volume (2) = {2};
Physical Surface (67) = {23};
Physical Surface (68) = {43, 57};
Physical Surface (69) = {31, 61};
Physical Surface (70) = {27};
Physical Volume (71) = {2};
Physical Volume (72) = {1};
Take a look here :
http://www.cfd-online.com/Forums/openfoam-meshing-gmsh/61888-problem-gmsh.html
Old   June 7, 2010, 11:42
Emanuele
If i go with lc under 0.1 (eg 0.04) and changing Z coordinates to a value equal to lc, the problem of 2D/3D re-appear. Suggestions?
Old   June 14, 2010, 19:09
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I am also getting the same FOAM Warning and gmshToFoam put all Physical Surfaces into 1 patch. Has anyone has the fix?
Thanks!
Pei
hsieh@rutgers:~/OpenFOAM/hsieh-dev/run> gmshToFoam -case magnets2DB 2magnets900ul_200ul_OF.msh
| \\ / O peration | Version: dev |
Build : dev-84cab37e7f6d
Exec : gmshToFoam -case magnets2DB 2magnets900ul_200ul_OF.msh
Date : Jun 14 2010
Time : 19:05:27
Host : rutgers
PID : 6583
Case : ./magnets2DB
nProcs : 1
Create time
Physical names:3
Surface 1 infinity
Surface 2 front
Surface 3 back
Starting to read points at line 11
Vertices to be read:159640
Vertices read:159640
Starting to read cells at line 159654
Cells to be read:448150
Cells:
total:149206
hex :9900
prism:139306
pyr :0
tet :0
CellZones:
Zone Size
0 149206
Skipping tag at line 607807
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 613
Found 298944 undefined faces in mesh; adding to default patch.
FaceZones:
Zone Size
End
phsieh2005 is offline   Reply With Quote
Old   June 15, 2010, 05:00
Emanuele
I had this problem using gmsh-2.5 from svn. With stable version 2.4.2, it should work
Old   June 15, 2010, 09:43
Pei-Ying Hsieh
Thanks nuovodna!
gmshToFoam worked when I switched back to gmsh 2.4.2 stable.
Pei
Old   July 8, 2010, 16:45
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Maybe not the issue here, but sometimes it is necessary to manually edit the boundary file generated by gmshToFoam and remove the defaultFaces block and reduce the number of patches by 1... This can help if you're having a problem with undefined faces.
louisgag is offline   Reply With Quote
Old   July 21, 2010, 17:06
Daniel
DVSoares is on a distinguished road
I use gmsh a lot with OF. In fact, louisgag has given the clue. I usually don't delete the patches.
When making a 2D simulation on OF using gmsh generated mesh it is necessary to edit the 'boundary' file under 'constant/polymesh' and set the 'type' for 'frontAndBack' and 'defaultFaces' to 'empty'. An example:
gmshToFoam generates this:
frontAndBack
    type           patch;
    nFaces        9072;
    startFace     8882;
just change to:
frontAndBack
    type           empty;
    nFaces        9072;
    startFace     8882;
Cheers,
DVSoares is offline   Reply With Quote
Old   July 30, 2010, 22:08
louisgag's Avatar
Louis Gagnon
Hi Daniel,
it is interesting to see that you have a different approach and set the 'defaultFaces' to 'empty'. I wonder if it would work for my 3D simulations as well..!
Cheers,
-Louis
Old   July 30, 2010, 22:23
Smile
  #13
Daniel
Hi Louis,
In my cases, in which I define a physical group for everything, the defaultFaces patch is actually empty (it ends at the same point it starts).
If you can test the approach I mentioned, to see if anything changes in your simulations, please post your observations, but don't forget to check the size of the default patches! (I believe it must be zero)
Cheers,
Daniel
Old   September 10, 2010, 15:30
louisgag's Avatar
Louis Gagnon
Hi Daniel,
I finally got around to trying your trick (leaving the defaultFaces patch in the boundary file (it is actually empty).
For me it worked well in both 2D and 3D!
Thanks for the advice,
-Louis
Old   October 1, 2010, 11:07
Default :)
  #15
kalyan
hardykalyan is on a distinguished road
Thank you Daniel, you saved my day. Deleting the default face worked pretty good for me.
hardykalyan is offline   Reply With Quote
gmshtofoam
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
