[snappyHexMesh] snappyhexmesh user guide
Old   March 7, 2012, 01:59
Smile snappyhexmesh user guide
张德胜
hei@ge is on a distinguished road
I am now learning snappyhexmesh ,but there are little paper to study.and i see the user guide ,but i can not download.If you have it,please give it to me .Thanks a lot.My e-mail is zhangdesheng0068@126.com.
hei@ge is offline   Reply With Quote
Old   March 7, 2012, 03:37
Disabled
anon_a is on a distinguished road
The user guide can be downloaded in pdf from
http://www.openfoam.org/docs/
There are several posts in the forum concerning snappyHexMesh, just use the search function first. You can also try some tutorials, such as the following in version 2.0.1
$FOAM_TUTORIALS/multiphase/LTSInterFoam/wigleyHull
$FOAM_TUTORIALS/multiphase/interPhaseChangeFoam/cavitatingBullet
$FOAM_TUTORIALS/heatTransfer/buoyantBoussinesqSimpleFoam/iglooWithFridges
$FOAM_TUTORIALS/heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater
$FOAM_TUTORIALS/mesh/snappyHexMesh/flange
$FOAM_TUTORIALS/incompressible/windSimpleFoam/turbineSiting
$FOAM_TUTORIALS/incompressible/simpleFoam/motorBike
$FOAM_TUTORIALS/incompressible/pimpleDyMFoam/wingMotion/wingMotion_snappyHexMesh
anon_a is offline   Reply With Quote
Old   March 7, 2012, 05:04
张德胜
Thanks a lot .anon_a,I have another question:after conduct snappyhexmesh,i should conduct the solver in which time .Tank you very much.
Old   March 7, 2012, 05:11
Disabled
If I understand correctly, you are wondering about the startTime that you must use after running sHM, because it produces several time directories. In fact, these directories contain the mesh in different stages.
I can think of the following two options: You may use "latestTime" in controlDict so that it uses the most complete version of the mesh (the last time directory). Or, you can call sHM with "snappyHexMesh -overwrite" so that the mesh is overwritten and you only have the initial conditions directory. In the latter case, you can use "startTime" in controlDict, as always.
I always choose the second option to avoid confusion, unless I only want to check the differences between various grid stages.
Old   March 7, 2012, 05:23
张德胜
You understand my question very correctly.If i choose the first opioion,i think i should copy some folder to the latest time folder.right?this folder should contain 0 folder.I hope you can give my fault.Thanks a lot.
Old   March 7, 2012, 05:34
张德胜
I understand it .Thank you very much.thanks.
guide, snappyhexmesh
Incorrect utility names in User Guide schoon OpenFOAM Bugs 1 October 23, 2008 11:32
CFX User Guide query siw CFX 0 August 21, 2008 03:15
[blockMesh] BlockMesh documentation User Guide clearance of mergePatchPairs proposals benru OpenFOAM Meshing & Mesh Conversion 0 June 9, 2008 02:22
Ist it only me that cant read the user guide pdf olle53 OpenFOAM 5 April 5, 2006 22:14
Fluent 5.5. What the differences with fluent 5.3?? confused FLUENT 2 July 29, 2001 21:58
