[blockMesh] square cylinder obstacle
Old   May 25, 2012, 19:01
Default square cylinder obstacle
fferroni is on a distinguished road
Hello
I am trying to make a blockMeshDict file for a 2D square cylinder obstacle (viewed from above), to show vortex shedding. I need it without centerline symmetry. Perhaps someone already has one, and would kindly share?
I have tried making it but I've just started openFOAM so I still don't have the hang of blockMesh. I get:
Check topology
Basic statistics
Number of internal faces : 8
Number of boundary faces : 32
Number of defined boundary faces : 32
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 4
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 221.
FOAM exiting
In my drawing, blocks 0 and 4 share 1 face, but I never specified in the boundaries since it was an internal face.
My square is a 1x1, with 2L on either side, 2L in front and 12L behind.
Can anyone shed some light please? It's Friday night and I'm stuck here trying to figure what I'm doing wrong
convertToMeters 0.001;
vertices
(0 0 -0.5)
(2 0 -0.5)
(3 0 -0.5)
(15 0 -0.5)
(15 2 -0.5)
(15 3 -0.5)
(15 5 -0.5)
(3 5 -0.5)
(2 5 -0.5)
(0 5 -0.5)
(0 3 -0.5)
(0 2 -0.5)
(2 2 -0.5)
(3 2 -0.5)
(3 3 -0.5)
(2 3 -0.5)
(0 0 0.5)
(2 0 0.5)
(3 0 0.5)
(15 0 0.5)
(15 2 0.5)
(15 3 0.5)
(15 5 0.5)
(3 5 0.5)
(2 5 0.5)
(0 5 0.5)
(0 3 0.5)
(0 2 0.5)
(2 2 0.5)
(3 2 0.5)
(3 3 0.5)
(2 3 0.5)
blocks
hex (0 1 12 11 16 17 28 27) (10 10 1) simpleGrading (1 1 1)
hex (11 12 15 10 27 28 31 26) (10 10 1) simpleGrading (1 1 1)
hex (10 15 8 9 26 31 24 25) (20 15 1) simpleGrading (1 1 1)
hex (15 14 7 8 31 30 23 24) (20 15 1) simpleGrading (1 1 1)
hex (1 2 13 12 17 18 29 28) (20 15 1) simpleGrading (1 1 1)
hex (14 5 6 7 30 21 22 23) (20 15 1) simpleGrading (1 1 1)
hex (13 4 5 14 29 20 21 30) (20 15 1) simpleGrading (1 1 1)
hex (2 3 4 13 18 19 20 29) (20 15 1) simpleGrading (1 1 1)
edges
boundary
pressure-outlet
type patch;
faces
(3 4 20 19)
(4 5 21 20)
(5 6 22 21)
velocity-inlet
type patch;
faces
(11 0 16 27)
(10 11 27 26)
(9 10 26 25)
wall-upper
type wall;
faces
(6 7 23 22)
(7 8 24 23)
(8 9 25 24)
wall-lower
type wall;
faces
(0 1 17 16)
(1 2 18 17)
(2 3 19 18)
obstacle-front
type wall;
faces
(15 12 28 31)
(14 15 31 30)
(12 13 29 28)
(13 14 30 29)
mergePatchPairs
fferroni is offline   Reply With Quote
Old   May 26, 2012, 04:26
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi;
the error is quite clear: you defined two adjacent blocks with different number of cells on their common face.
In you case the face is that one between block #0 and block #4 which are:
they share a face parallel to the Y axis, if you see though they have a different number of cells along that direction: 10 for block 0 and 15 for block 4.
Since also block 7 has 15 division along the Y direction, changing block 1 to this may solve your problem:
hex (0 1 12 11 16 17 28 27) (10 15 1) simpleGrading (1 1 1)
lovecraft22 is offline   Reply With Quote
Old   May 26, 2012, 04:48
Thumbs up
Aaaah... ok!
I now understand what the error means. I didn't know you had to match the block divisions at interfaces (although it's logical you would need to...)
There were other ones that were not matched, but I got it working
Thank you!!!
Fran
Turbulent flow around a square cylinder paulzhang SU2 2 August 13, 2017 23:55
[ICEM] Flow over 2-d square cylinder GAURAV KUMAR ANSYS Meshing & Geometry 1 March 2, 2015 12:26
[blockMesh] beginner question: requesting tips on how to proceed with creating a square cylinder Uncustom OpenFOAM Meshing & Mesh Conversion 0 September 20, 2014 12:39
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 15:16
drag calulation over a square cylinder sex00 Main CFD Forum 4 February 2, 2001 07:16
