[Commercial meshers] A problem to use the mesh made by ICEM in openfoam |
June 4, 2016, 12:17 |
Hong
Rep Power: 9 |
I made a two-dimensional airfoil mesh by ICEM and saved it in .msh file format. But when I use the fluentMeshToFoam in openfoam(ubuntu), I have a problem and I cannot understand it. I offer the pictures of its running result.
June 5, 2016, 14:36 |
Hrvoje Jasak
Rep Power: 33 |
Export the mesh in ascii format and all will be well.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 6, 2016, 00:20 |
Hong
Rep Power: 9 |
Really thank you. But how can I export my mesh in ascii format? ICEM can have this function, right?
June 6, 2016, 02:54 |
Hong
Rep Power: 9 |
I have solved the problem I had before. Really thank you for your advice!
But I have a new problem, the following is the terminal log: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-119cac7e8750 Exec : fluentMeshToFoam NACA0012.msh -scale 0.1 Date : Jun 06 2016 Time : 14:43:30 Host : "katorirea-pc" PID : 3373 Case : /home/katorirea/OpenFOAM/katorirea-3.0.1/run/tutorials/incompressible/icoFoam/nacaair nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time fileName::stripInvalid() called for invalid fileName classimmerseBoundaryPolyPatch~ For debug level (= 2) > 1 this is considered fatal Aborted (core dumped) |
[Commercial meshers] Importing ICEM Multiregion Mesh In OpenFOAM | Aditya Patil | OpenFOAM Meshing & Mesh Conversion | 1 | May 8, 2017 21:33 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[ANSYS Meshing] problem in HEX-tet mesh generation in ICEM | himanshu28 | ANSYS Meshing & Geometry | 24 | October 28, 2012 11:17 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 08:52 |
ICEM Tetra mesh, Size reduction and Skewness problem | Catthan | ANSYS Meshing & Geometry | 6 | December 5, 2010 19:39 |
