[Commercial meshers] FluentMeshtoFoam error
Like Tree1Likes
  • 1 Post By fra76
Old   March 5, 2008, 04:39
Default FluentMeshtoFoam error
Sukratu Barve
sukratu is on a distinguished road
Looks like the lexing is okay as it says. Whats happening later? I have copied the message I get below
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : fluentMeshToFoam . schannel ../Ser_D_1mm_Rc-2_366720_Pave.msh
Date : Mar 05 2008
Time : 14:42:58
Host : sukratu.cms.unipune.ernet.in
PID : 4878
Root : /home/sukratu/OpenFOAM/sukratu-1.4.1/run/mycase1/icoFoam
Case : schannel
Nprocs : 1
Create time
Dimension of grid: 3
Number of points: 375719
Reading points
number of faces: 1108888
Reading mixed faces
Reading mixed faces
8(5f9 bf0 4 3Reading mixed faces
Reading mixed faces
Reading mixed faces
Number of cells: 366720
Other readCellGroupData: 2 1 59880 1 4
Reading uniform cells
Read zone1:2 name:fluid patchTypeID:fluid
Reading zone data
Read zone1:3 name:perioidc_shadow patchTypeID:shadow
Reading zone data
Read zone1:4 name:perioidc patchTypeID:periodic
Reading zone data
Read zone1:5 name:interior patchTypeID:interior
Reading zone data
Read zone1:6 name:wall patchTypeID:wall
Reading zone data
Read zone1:8 name:default-interior patchTypeID:interior
Reading zone data
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
Building patch-less mesh...--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 577
Found 17456 undefined faces in mesh; adding to default patch.
done.
Building boundary and internal patches.
Creating patch 0 for zone: 3 start: 1 end: 1528 type: shadow name: perioidc_shadow
--> FOAM FATAL ERROR : fluent patch type shadow not recognised.#0 Foam::error::printStack(Foam:stream&) in "/home/sukratu/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/sukratu/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 main in "/home/sukratu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/fluentMesh ToFoam"
#3 __libc_start_main in "/lib/libc.so.6"
#4 __gxx_personality_v0 in "/home/sukratu/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/fluentMesh ToFoam"
From function fluentToFoam::main(int argc, char *argv[])
in file fluentMeshToFoam.L at line 1330.
FOAM aborting
Aborted
sukratu is offline   Reply With Quote
Old   March 5, 2008, 07:18
Default You have shadow surfaces in yo
Francesco Del Citto
fra76 is on a distinguished road
You have shadow surfaces in your Fluent mesh (i.e., internal faces set as wall). Try fluent3DMeshToFoam. It should handle them!
Francesco
rmn_990 likes this.
fra76 is offline   Reply With Quote
Old   March 6, 2008, 23:52
Default Nope. Looks like the 3D solver
Sukratu Barve
Nope. Looks like the 3D solver is facing trouble too
Here is what I did and the message it gave.
[sukratu@sukratu icoFoam]$ fluent3DMeshToFoam . schannel ../Ser_D_1mm_Rc-2_366720_Pave.msh
Exec : fluent3DMeshToFoam . schannel ../Ser_D_1mm_Rc-2_366720_Pave.msh
Date : Mar 07 2008
Time : 10:07:58
PID : 3549
Case : schannel
Nprocs : 1
Create time
--> FOAM FATAL ERROR : Do not understand characters:
From function fluentMeshToFoam::lexer
in file fluentMeshToFoam.L at line 703.
FOAM exiting
Old   March 7, 2008, 04:14
Default You probably have DOS linefeed
Mattijs Janssens
You probably have DOS linefeeds instead of Unix linefeeds. Try running something like dos2unix to convert the file.
Old   March 7, 2008, 22:54
Default Looks like there were dos line
Sukratu Barve
Looks like there were dos linefeeds because dos2unix did process the files. However, the
error persists when I use Fluent3DMeshtoFoam
(as well as FluentMeshtoFoam which I tried just in case that went through for some reason).
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
