[Commercial meshers] fluentMeshToFoam error
Old   May 31, 2012, 10:58
Default fluentMeshToFoam error
Remy Peyrache
Wugabapalmu is on a distinguished road
Hi all,
I designed a rather simple 2D-mesh using PointWise Gridgen and exported it as a Fluent .cas file. When trying to convert it with fluentMeshToFoam, I get the following error message :
--> FOAM FATAL ERROR:
Problem : cannot find a single face in the mesh which uses vertices 4(5375 379 5937 10933)
From function findFace(const primitiveMesh&, const face&)
in file fluentMeshToFoam.L at line 857.
FOAM exiting
From what I could make out looking into the fluentMeshToFoam.L file, OF can't find the face based on this 4(5375 379 5937 10933) vertex. Any idea why that is ? I've been trying to redesign the mesh for 2 days and I always get this same message (not always with the same vertex though).
Thanks !
Wugabapalmu is offline   Reply With Quote
fluentmeshtofoam, gridgen
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
