[mesh manipulation] MakeAxialMesh for flow between two cylinders
Old   September 27, 2012, 03:54
Unhappy MakeAxialMesh for flow between two cylinders
ali jafari
ali jafari is on a distinguished road
hi
I solved flow between two cylinders by COMSOL and now I'll do it by OF (I am beginner). I want to use makeaxialmesh utility and Gambit but I dont know define
-axis for makeaxialmesh (red line in pictures)!!
do I need to do something on gambit model ?
please guide me
Regards
ali jafari is offline   Reply With Quote
Old   September 28, 2012, 08:54
Assistant Moderator
Bernhard Gschaider
Originally Posted by ali jafari View Post
hi
please guide me
Regards
Have a look at the axialCavity-Testcase that is in the SVN-repository. It defines exactly such a case (using the rotationDict)
Just one remark: you might prefer creating a quad-mesh instead of the triangles (and BTW: gambit is a bit of an overkill for that geometry)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Flow Around four cylinders in square configuration shzinwoyk Main CFD Forum 1 April 13, 2015 16:44
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 10:02
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 09:22
2D Aerofoil with rotating cylinders - Help & Advice! Bluejay OpenFOAM 1 December 31, 2012 04:40
[mesh manipulation] makeAxialMesh - installation issues simulator4711 OpenFOAM Meshing & Mesh Conversion 3 March 21, 2012 07:59
