[Other] what means information checkMesh give?
Like Tree2Likes
  • 1 Post By akidess
  • 1 Post By akidess
Old   June 30, 2013, 13:04
Default what means information checkMesh give?
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
what does mean boundary openness and Max cell openness?
is this mesh OK? aspect ratio till what value is acceptable?
Checking geometry...
    Overall domain bounding box (0 0 0) (0.069 0.004 0.003)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-5.347430223e-18 -1.447816733e-16 -9.586797705e-16) OK.
    Max cell openness = 1.983242651e-16 OK.
    Max aspect ratio = 3.171630836 OK.
    Minimum face area = 3.888093411e-09. Maximum face area = 5.2674561e-07.  Face area magnitudes OK.
    Min volume = 1.166428023e-11. Max volume = 5.832140299e-11.  Total volume = 8.28e-07.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.0002143106966 OK.
    Coupled point location match (average 0) OK.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 1, 2013, 04:31
akidess's Avatar
Anton Kidess
I believe openness is only a concern when doing CAD import. CAD geometries tend to be not perfect and can lead to unwanted gaps in your geometry/mesh on import. The values in your log file are good (close to zero).
immortality likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   July 1, 2013, 05:27
Ehsan
Hi Anton
thanks so much.so don't need to worry about them.
I read somewhere as I remember vaguely that aspect ratio should be lower than 5(?) for better stability and accuracy as I remember,is it true?
Old   July 1, 2013, 05:35
akidess's Avatar
Anton Kidess
Lower is better, but there is no fixed rule. In some applications you cannot avoid high values, and still get reasonable results.
Recommended reading: http://www.sharcnet.ca/Software/Flue...ug/node167.htm
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 05:16
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 21:39
How to give velocity and temperature gradient's type of boundary conditions in fluent Kishorechand Main CFD Forum 0 April 4, 2012 05:01
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Is there anyone can give me information ZHU Main CFD Forum 3 June 12, 2000 23:31
