[snappyHexMesh] refined blockmesh for snappyhexmesh
Like Tree1Likes
  • 1 Post By Antimony
Old   March 20, 2016, 06:30
Default refined blockmesh for snappyhexmesh
Tobi
TOM01 is on a distinguished road
does anybody know wether it is possible to use region wise refined blockmeshes as input for snappy hex mesh.
Or more general: Is it possible to use as input for the castellation other meshes than regular hex meshes?
I set up a refined blockmesh as in the attached picture.
But snappy hex mesh says:
--> FOAM FATAL ERROR:
cell 1590 of level 0 uses more than 8 points of equal or lower level
Points so far:8(2024 2025 2035 2036 2134 2135 2145 2146)
The cell is in first layer of the refined part of the mesh. (2nd picture below)
TOM01 is offline   Reply With Quote
Old   March 20, 2016, 07:58
Antimony is on a distinguished road
From what I have seen, you need to have pretty much only hexes to be able to run snappyHexMesh (anything more than 8 vertices for a block and it doesn't work)
Refining the original mesh in only particular directions over only a portion of the mesh does not allow you to run snappyHexMesh (refining leads to more vertices within the same block and so it shows that error)
Hope this helps.
Cheers,
Antimony
ellenripley likes this.
Antimony is offline   Reply With Quote
Old   March 20, 2016, 09:20
Tobi
Thank you Antimony.
Meanwhile I learned that the same what I wanted to do I can do with dedicated refinement zones in snappyHexMeshDict.
Do you know if it is possible in snappy to define that zones are getting refined only in x/y and not in z direction?
Old   March 20, 2016, 19:48
Yes, refinementRegions would help you refine a selected region. Your cells will need to have at most 8 vertices for this.
And nope. AFAIK, snappy does refinement in all three directions and you can't limit it to any particular direction(s).
Cheers,
Antimony
Old   March 21, 2016, 02:35
Tobi
Thanks a again.
Meanwhile I could get a working mesh with acceptable refinement.
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
2D AMR - matching faces that are not refined with refined faces chrisb2244 OpenFOAM Programming & Development 9 June 22, 2016 00:56
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
