[snappyHexMesh] Strange lines with snappyHexMesh |
May 18, 2016, 05:16 |
Tanja
Hello everyone!
I'm new in OpenFoam and I'm trying to repeat DTCHull tutorial with my own stl geometry. It works rather good, but I always see strange lines in surrounding mesh far away from the stl (see attached file). Could please anyone explain me, what am I doing wrong and how to avoid it? Thank you. |
May 19, 2016, 18:36 |
Rep Power: 24 |
Is this a cut section? These just look like Paraview rendering. You can turn these off with different methods, but which one to use depends on what you are viewing here.
May 20, 2016, 08:04 |
Tanja
Thank you, me 3840. It was really rendering problem. I've turned on "Crinkle clip" in Paraview and now can see the normal mesh.
snappyhexmesh |
[snappyHexMesh] Curved lines appearing on mesh with snappyHexMesh | gabrielmsa | OpenFOAM Meshing & Mesh Conversion | 1 | October 31, 2018 02:17 |
[snappyHexMesh] Strange SnappyHexMesh behavior at the symmetry plane | ripperjack | OpenFOAM Meshing & Mesh Conversion | 6 | March 3, 2017 13:39 |
[snappyHexMesh] OpenFoam FATAL ERROR SnappyHexMesh search lines never written | enginpower | OpenFOAM Meshing & Mesh Conversion | 8 | December 30, 2016 08:19 |
[TurboGrid] Hub&Shround part Strange lines are created. | ByeongLae | ANSYS Meshing & Geometry | 0 | May 8, 2014 03:45 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
