[snappyHexMesh] handling of baffle regions or surfaces with zero thickness with snappyHexMesh |
July 2, 2012, 09:44 |
I'm struggeling with the creation of a mesh that includes a surface of zero thickness. I've tried various things so far. 1. Define the baffle region as a faceZone with the following entry in snappyHexMesh: ... refinementSurfaces { baffle} ... Snappy then generates a nice mesh and the baffle region is nice and smooth. But then I'm stuck. Since 'baffle' is now a faceZone and not a boundary patch I can not define it as a wall and set boundary conditions. I've tried using the 'createBaffles' command to turn the faceZone into a boundary patch which seems to work fine. But the checkMesh fail in various areas: - Multiple regions which are not connected by any face - 92254 conflicting points for multiply connected surfaces - 52 skewfaces Also simulation crashes when solving for p with a printStack error. 2. If I don't define the baffle region as a faceZone as seen in 1. but a normal surface, I end up with two intersecting patches in the baffle region which messes up my geometry. So does anyone have any advice for me? Is there maybe another way to convert a faceZone into a patch? I've also considered 'createPatch', but since I don't know how to convert a faceZone into a faceZone, I'm stuck there as well. I'd highly appreciate any suggestions!! Regards Stefanie |
[ANSYS Meshing] Baffle (zero thickness) wall | sina_mech | ANSYS Meshing & Geometry | 5 | July 14, 2022 01:58 |
[snappyHexMesh] problem with snappyHexMesh | kanes | OpenFOAM Meshing & Mesh Conversion | 10 | January 26, 2016 06:11 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 14:46 |
[snappyHexMesh] SnappyHexMesh segmentation Fault | nithishgupta | OpenFOAM Meshing & Mesh Conversion | 1 | December 18, 2014 04:03 |
[snappyHexMesh] snappyHexMesh with zero Thickness surface imported from a Geometry | hfs | OpenFOAM Meshing & Mesh Conversion | 0 | September 4, 2012 11:41 |
