[snappyHexMesh] Salomone etc. instead of blockMesh
Old   October 12, 2018, 04:15
Default Salomone etc. instead of blockMesh
Kevin Habrock
Kevin.H is on a distinguished road
Hey Guys,
I would like to know, if it is possible to mesh with Salomone instead of blockMesh for the the backround mesh, to use in the next step snappyhexMesh.
I have tried it with different types of meshes in the last hours, but It did not work on my computer.
I was a little bit confused that I couldn`t find anything about this idea of workflow.
At first I thought the .m4 Format would be a good opportunity. But on the second look, it seems to be very complicadet to create geometries on this way.
Maybe you have some experience on this topic.
Thank you and best regarts!
Kevin
Last edited by Kevin.H; October 12, 2018 at 05:11. Reason: another idea which i would like to share
Kevin.H is offline   Reply With Quote
Old   October 12, 2018, 05:10
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Yes it works fine.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   October 12, 2018, 05:58
Kevin Habrock
Originally Posted by linnemann View Post
Yes it works fine.
Thank you Linnemann for your quick response,
Everytime I get an error like this:
--> FOAM FATAL ERROR:
cell 986 of level 0 does not seem to have 8 points of equal or lower level
cellPoints:4(2606 2609 2611 1258)
pointLevels:4{0}
I have tried to refign the meshs etc but it still doesn`t work. Is there anything I have to note when I use Salomone in combination with snappy?
Old   October 15, 2018, 04:50
Kevin Habrock
Good Morning Formes,
maybe I should explain what I am trying to do with SnappyhexMesh.
I work for 2 weeks with OpenFoam an I have heard that SnappyHexMesh is, especially for complex Geometries, the best way to produce Meshes.
My basic case is really simple but in a few weeks I hope to simulate other more complexer cases. I would like to use this way of meshing, because the basic-mesh with simple BlockMesh isn´t uniform enough.
The importing of the first zylinder works very fine (ideasUnvToFoam Mesh.unv). I get the PolyMesh folder with all informations.
But when I try to use snappyHexMesh a fatal Error is the result.
--> FOAM FATAL ERROR:cell 986 of level 0 does not seem to have 8 points
In Older CFD-Online discussions I have read that sometimes the refinement ratios could be the problem.
So in the next step I disabled the snap-, and add Layers-opportunity in the snappyHexMeshDict. I thought that the prismlayers or other refinements produce this Error.
But it still doesn´´t work.
Could you please describe me your Workflow?
Is there any limitation in Salome ?
Which kind of mesh do you use ?
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
